Old 04-28-2023, 07:01 PM   #1
SKYCHSR
Drives: 2017 Toyota 86 Halo
Pre Facelift (ZN6) Tail Light Fitment on Facelift Model
wanting to try my hand at illumaesthetic's DIY LED kit for my 2017 86, however they are made to fit the ZN6 tail light housing. I've seen many posts made about swapping the tail lights the other way around but wanted to know if I would run into any issues doing it this way
SKYCHSR is offline   Reply With Quote
Old 04-28-2023, 07:43 PM   #2
villainous_frx
Off to the track!
villainous_frx's Avatar
Drives: '14 Lava 86, '13 WRB BRZ
They are plug and play.
villainous_frx is offline   Reply With Quote
Old 04-28-2023, 07:48 PM   #3
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Doubt it will work because the 17+ tails are already LED and sealed and you can't just swap bulbs to LEDs, etc like you can with the 13-16 tails.
Why not email illumaesthetic and ask this quesiton?
Edit: Are you asking if you can use the illumaesthetic kit on your 17 tails, or just if you can swap 13-16 tails into your 17?
Originally Posted by humfrz
I'm old and lazy
Old 04-28-2023, 08:15 PM   #4
SKYCHSR
If I could just swap 13-16 tails into my 17. I did email them on what you thought I was asking but didn't ask if 13-16 would fit on 17+. i have found they will. just have to figure out wiring. thanks anyway.
Old 04-29-2023, 02:16 AM   #5
Clipdat
Proud of BOXER
Clipdat's Avatar
Yep, both types are compatible with each other. Pretty cool.
Anyway, good luck with your project and post up the final results!
I'm old and lazy
DIY: pre-facelift to facelift steering wheel and cluster swap TRS DIY (Do-It-Yourself) Guides 16 10-22-2024 02:12 PM
Facelift Intake Manifold to Pre-Facelift AutoCulture Scion FR-S / Toyota 86 GT86 General Forum 49 02-09-2023 06:25 PM
GT86 2017 facelift bumper installed on pre-facelift 2015 model yoongjun Cosmetic Modification (Interior/Exterior/Lighting) 2 01-20-2021 11:28 AM
Facelift tail lights Yoshoobaroo Exterior Parts (Aero, Lighting, Etc.) 3 09-12-2019 02:20 PM
Facelift LED headlight to Pre facelift? teppei Cosmetic Modification (Interior/Exterior/Lighting) 0 09-17-2017 07:25 AM
