Old 04-24-2023, 08:12 PM   #1
Robbie7c
Drives: 2013 Subaru BRZ
Wheel setup question
Ok so, I’ve looked thru the wheel fitment guide but there seems to be some conflicting info.
I’m looking at getting 17x8 wheels with a +40mm offset. Tires will be 245/40r17. Car is completely stock, should these clear alright? Should I expect any rubbing at full lock?
Car is a 2013 BRZ, like I said 100% stock
Robbie7c is offline   Reply With Quote
Old 04-25-2023, 12:16 PM   #2
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
https://www.willtheyfit.com/
You should be fine. Plug the numbers in there ^^ and compare it to stock and yeah, you should be fine.
EDIT: I'm on coils, I have no idea if you're on stock suspension. My bad. That said, I have been on 18x8.5+45 in the front with no rubbing.
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
Old 04-25-2023, 01:28 PM   #3
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
No rubbing issues. Ran the near identical setup with 225/45r17, with camber and crash bolts and had plenty of clearance.
The Following User Says Thank You to RToyo86 For This Useful Post:
Wally86 (04-25-2023)
Exhaust Setup Question FewTooManyBeers Engine, Exhaust, Transmission 3 07-01-2018 09:31 PM
Question: 195/60 R16 for Winter Setup ivtaku7 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 11-30-2015 11:23 AM
FS: Sparco steering wheel setup/ b2autodesigns wheel adapters sebastiansim NY / NJ / CT / PA 1 11-12-2015 07:57 AM
just another exhaust setup question Boofneenee Engine, Exhaust, Transmission 4 09-30-2014 08:07 PM
Staggered Setup Question Chewie4299 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 04-08-2013 09:33 PM
