Old 04-16-2023, 08:23 PM   #1
DSW
Drives: 2016 BRZ
Squealing from engine bay
Starts after a couple seconds on start up, Goes away for the most part when on throttle, comes back off throttle. only between ab 500-1000 rpm. The car is tuned if that has anything that may play in. It continues and gets louder after car is stopped. Im lost on what it may be ive never heard this type of sound. The car has oil and its not a belt squeak. video of squeal https://youtube.com/shorts/V6HWCAJrhhY?feature=share
Im unsure what it is or what to look up to find a similar post.
So thank you in advance.
DSW is offline   Reply With Quote
Old 04-16-2023, 08:28 PM   #2
humfrz
Sounds to me like an idler pulley is running dry.
Old 04-16-2023, 09:26 PM   #3
DSW
Drives: 2016 BRZ
So id just need to grease the bearing for the idler pulley? Thank you!
Old 04-16-2023, 09:58 PM   #4
DSW
Drives: 2016 BRZ
I just looked at the idler pulley and took it off and everything looks fine it shakes a little bit when the car is running but other than that the bearing looks no and has no squealing coming from it when i spin the bearing by hand.
Old 04-17-2023, 01:42 AM   #5
humfrz
OK, my second guess is that it might be the water pump making that noise, however, that would be unusual on these cars.
I suggest you also make a "stethoscope" out a long handled screwdriver or a metal rod and place one end of it on the alternator and AC compressor to see if you can isolate where the sound is coming from.
Let's wake up ol @Tcoat and see if he has any ideas.
Old 04-17-2023, 07:04 AM   #6
Vacuum or exhaust leak? It is not a moving part as it briefly continues after the engine is stopped.
Old 04-18-2023, 02:52 AM   #7
Ultramaroon
not playing cards
Ultramaroon's Avatar
^^^this^^^
OP, my money's on brake booster vacuum leak downstream of the check valve.
Old 04-18-2023, 11:40 AM   #8
Ultramaroon
not playing cards
Good thing OP posted an excellent recording
Old 04-18-2023, 11:44 AM   #9
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
My vote is vacuum.
Either that or..
Old 04-18-2023, 12:12 PM   #10
Ultramaroon
not playing cards
Loud squealing noise at 80+km/h Untitled Issues | Warranty | Recalls / TSB 3 04-08-2021 03:06 AM
Odd Squealing Sound When Driving effigy Issues | Warranty | Recalls / TSB 2 10-10-2019 06:46 PM
Low speed tires squealing emishor86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 12-25-2016 10:43 AM
Squealing while turning haavardnk Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 04-11-2016 11:40 AM
Squeaking or squealing window Cjm005 Scion FR-S / Toyota 86 GT86 General Forum 1 12-25-2012 12:19 AM
