Old 04-11-2023, 07:19 PM   #1
Dyniek
Dyniek's Avatar
Drives: Toyota GT86 TRD '19
Lightbulb Budget Performance mods that aren’t noisy?
So I would like to increase power a little bit in my car, but I’m not sure where to start.
I don’t want to get a turbo or a supercharger because it’s too expensive and I don’t want to risk blowing my engine.
Many people say to get a catless header, but I’ve a TRD edition with TRD catback and it’s already pretty noisy, and the noise is really loud when going on a highway. Also I would like to pass an inspection.
So, are there any other mods that I can make to increase power even if it’s just a few horsepower? Thanks!
Dyniek is offline   Reply With Quote
Old 04-11-2023, 07:35 PM   #2
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Lightweight wheels and tires.
If a picture is worth a thousand words, a model is worth ten thousand pictures.
Also: "Build Thread"
Spuds is online now   Reply With Quote
RToyo86 (04-11-2023), SCFD (04-12-2023)
Old 04-11-2023, 07:54 PM   #3
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
Is E85 available in Poland? You mentioned passing an inspection so obviously you have those concerns where you live. If E85 is readily available, and you can legally use it, it will give you a significant gain without adding any noise. You'll need an open flash tablet, which would cost you about $400 US.
Qwimby1 is offline   Reply With Quote
Old 04-11-2023, 08:46 PM   #4
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
NA these engines are already pretty tapped out.
E85 and/or an aftermarket header are your two main options. Beyond that you aren't going to notice gains other bits would give you.
Old 04-12-2023, 04:12 AM   #5
Dyniek
Dyniek's Avatar
I already have TRD wheels as well as pilot sport 4.
E85 isn’t avalible in my city, and there are probably only few gas stations that sell this. I saw some people on polish groups that make their own E85, but that’s not something I would want to do.
What about some smaller things? Like specific oil, oil filter, air filter or whatever?
Old 04-12-2023, 05:54 AM   #6
Dyniek
Dyniek's Avatar
What about tune but without header? Would it increase any power?
Old 04-12-2023, 06:58 AM   #7
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
The first mods I did so far are the Whiteline diff insert and TRD Transmission mount. The car isn't any faster but it feels faster ha. It's also just makes the car feel more sporty and more fun to drive. Shifts a bit bit better etc etc.
I am having the TRD motor mounts installed this week and I have subframe bushing inserts as well I hope to install before my next track day.
Beside this my car is stock and the the mods really added to the experience of driving around town.
autoracer86 is offline   Reply With Quote
Old 04-12-2023, 07:42 AM   #8
RToyo86
RToyo86's Avatar
Briefly tried OFT stg1 on my 2017 when swapping headers around and didn't notice a difference. Unlike with a catless/Catted header which gives you a more noticeable power bump. Even that is still subtle, most of the power is noticeable from 3000-5000
A high flow drop in filter + a inlet tube can net a few hp. You aren't going to feel the difference but there is something there.
The Following User Says Thank You to RToyo86 For This Useful Post:
SCFD (04-12-2023)
Old 04-12-2023, 09:49 AM   #9
ZDan
ZDan's Avatar
Drives: '23 BRZ
Doubtful. Tune really only required if you made other changes, like a catless header. I don't think a catback would count as a significant enough change that you'd benefit from a tune. Specifically asked my known/respected tuner about doing iterations to get an optimized tune on a stock setup, he said don't bother... We did multiple iterations on tuning my car for ACE-350 header and the results, particularly midrange were pretty stellar! Was thinking of going back to stock to get "points" back for my time-trialling class...
Old 04-12-2023, 04:42 PM   #10
SCFD
Perrin inlet tube, or equivalent, that removes the factory sound tube. It will net some power up top while making the car more comfortable (less engine noise).
SCFD is offline   Reply With Quote
Old 04-17-2023, 05:36 PM   #11
Dyniek
Dyniek's Avatar
What about a catted header? Would it increase performance? I’m just trying to get more torque at the 3-4k and get more linear torque.
And how much did the sound increase in your opinion from catless header? I can’t stand my car’s noise at 90mph, and it’s only a catback.
Also, is the torque difference noticeable a lot? Like for example do you fell being pushed into the seat when accelerating?
Old 04-17-2023, 06:44 PM   #12
Stephen02
Stephen02's Avatar
Drives: 2013 Manual Trans FR-S
Catted header probably isn't worth the money for most people but it's up to you. It will increase low and mid-range torque a little bit and change the sound. Gains at the top end probably won't be noticable.
Stephen02 is offline   Reply With Quote
Old 04-18-2023, 06:28 AM   #13
new2subaru
Weight Weenie
Drives: 15 FR-S
Another option, you can change your diff gearing (ring and pinion) and/or drop weight.
https://nitro-gear.com/search-pl?fit...tical&limit=50
The Following 2 Users Say Thank You to new2subaru For This Useful Post:
Teseo (04-19-2023), whataboutbob (04-18-2023)
Old 04-18-2023, 08:30 AM   #14
whataboutbob
AutoX-10/10ths every run
+1 on the final drive change. A Cusco 4.556 Vs the stock 4.10 will give you a noticeable increase in the feel of acceleration. It's definitely NOT a budget mod though.
Build thread:Here
budget, discussion, horsepower
Anyone else not planning on too much performance mods? suhhh GR86 General Topics (2nd Gen 2022+ Toyota 86) 55 10-05-2021 09:43 AM
Top 3 performance mods thekevinvo FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 33 10-09-2020 09:11 AM
Mods on a tight budget-Raven FR-S ZachTTerrell Member's Car Journals 0 06-12-2015 12:37 AM
Performance mods. Fred Flintstone Scion FR-S / Toyota 86 GT86 General Forum 3 10-11-2014 03:08 PM
Got my BRZ for two weeks, looking for a performance mods? Drakelee117 BRZ First-Gen (2012+) — General Topics 33 09-02-2014 05:22 PM
