Old 04-05-2023, 06:12 PM   #1
DarkSunrise
DarkSunrise's Avatar
300+tw tire chunking
Has anyone (intermediate/advanced) managed to track on 300+tw tires and not have their tires chunk? If so, what’s your setup and which tires?
I ran 3 sessions on Dunlop Sport Maxx RT2 and my left tires (CW track) were falling apart. This is a stock suspension 2022 BRZ with -2.5 degrees front camber. I was hoping to run stock suspension and low grip tires for a while until I had more time to track regularly again, but don’t want to be constantly destroying my street tires either. Granted I was pushing pretty hard and using trail-braking to get the front end to turn in, but curious if it’s these tires or if all 300tw tires will be like this. Maybe I just need to go back to track tires.
2022 BRZ Build
2013 FR-S Build
Old 04-05-2023, 08:31 PM   #2
strat61caster
strat61caster's Avatar
Two options:
Drive slower
Get better tires
Rs4 and the gtradial beaters are perfectly fine Street tires.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
DarkSunrise (04-06-2023), SCFD (04-05-2023)
Old 04-05-2023, 10:13 PM   #3
SCFD
Two options:
Drive slower
Get better tires
Also want to add:
  • Be smoother with the inputs
  • Use less inputs
  • Drive fewer laps per session
  • Spray water on tires between sessions
SCFD is offline   Reply With Quote
The Following User Says Thank You to SCFD For This Useful Post:
Old 04-06-2023, 10:25 AM   #4
DarkSunrise
Two options:
Drive slower
Get better tires
I think that's going to be the answer. For some reason I thought 300tw tires would deal with track use (abuse?) better than this but I guess not.
Originally Posted by SCFD View Post
Also want to add:
  • Use less inputs
Interesting, I've only seen water spraying for autox. Wouldn't the tire cool sufficiently in the 1+ hr between sessions? Smoother/less inputs would definitely help. Probably just need to dial things back overall and accept what the car's giving me, or use better tires.
2022 BRZ Build
2013 FR-S Build
Old 04-06-2023, 12:07 PM   #5
SCFD
Dialing things back and/or driving better and/or driving what the car and tires will allow will definitely help. As will just using better tires in general that can withstand the abuse.
You mentioned trail braking into corners which is probably the first thing you can try cutting back on.
The water spraying would depend how your events are run. I've been to ones with 1 hour lapping and few people/cars will be able to stay out for that long. I've also been to events without structured run sessions. I personally break down those down into roughly 15 min stints with a 15 min break in between (I don't bother spraying tires though).
Old 04-06-2023, 02:10 PM   #6
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
I’ve never seen/had much love for Dunlop tires.
What is their manufacture date? That rubber could be past it’s prime.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos
Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms
235F/245R Conti ECS on TRD/Enkei wheels (street),
245/40 sq. ECF on 17x8 720Form GTF2 wheels (track)
Muskoka800 is offline   Reply With Quote
The Following User Says Thank You to Muskoka800 For This Useful Post:
Old 04-06-2023, 03:17 PM   #7
DarkSunrise
Yeah that was my first thought but all have 1822 DOT codes, so within a year old.
Thinking about it more, I think I'm going to throw my old coilovers on the car and increase front camber to -3.5. Should help the car rotate a bit more on entry. Inevitably this car is becoming a clone of my 1st gen lol.
2022 BRZ Build
2013 FR-S Build
Old 04-06-2023, 04:00 PM   #8
Overheating the tire and literally tearing it with too much steering input for the conditions.
You also need more camber for that tire to help cut it.
DarkSunrise (04-07-2023)
Old 04-06-2023, 04:03 PM   #9
CedN
CedN's Avatar
Drives: 2013 GT86 fully standard
I have Goodyear Eagle f1 assy 3(215 std size) that came on the car, old in other words. Ive hammered these as hard as i can, including deep trail braking. I wore them half way down to the rim edge . However they somehow keep up, no chunks at all and wear rate is surprisingly reasonable considering the use. But they do like a slower cool down lap in between, and its smart not to have to long sessions. Should be other semi high performance tyres out there that can keep up, the Dunlops doesnt seem to though.
2013 GT86, fully standard daily and occasional track day car
CedN is offline   Reply With Quote
The Following User Says Thank You to CedN For This Useful Post:
Old 04-07-2023, 01:27 AM   #10
DarkSunrise
That's a great explanation and makes sense given the location and direction of the tearing on the tread blocks. I also don't think it helped that the tire was nearly new with full tread depth.
BTW you were right about the XP10's, got some fade even on SOWS.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
CSG Mike (04-07-2023)
Old 04-16-2023, 11:23 PM   #11
eyeballs
Drives: '22 BRZ
Try the Yoko V601. 280tw and handle track use with no problems.
eyeballs is offline   Reply With Quote
Brake Pad Chunking from Track radon55 Tracking / Autocross / HPDE / Drifting 13 07-07-2020 01:26 PM
Taking Care of Tires on Track - How to Avoid Chunking OND Tracking / Autocross / HPDE / Drifting 24 06-06-2017 12:10 AM
FS: Stock Tires (some chunking) bottle Canada Classifieds 4 07-28-2015 01:16 PM
Stock Tire Chunking PICS RMP Tracking / Autocross / HPDE / Drifting 12 10-27-2014 07:50 PM
Dunlop Z2's Chunking, Defective? kanundrum Tracking / Autocross / HPDE / Drifting 19 03-30-2014 09:49 PM
