Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 03-31-2023, 02:22 AM   #1
ACT86
ACT86's Avatar
Drives: English, French, Swedish & Japanese
Gen 2 seat height
Just wondering if anyone has found a solution to lower the Gen 2 drivers seat slightly.
I find I’m up a bit higher than my Gen 1 and just can’t seem to get as comfortable.
Hoping there may be a simple solution (back in the days with French hot hatches there were often spacers you could remove, although I can’t see this being the case).
Thanks in advance.
ACT86 is offline   Reply With Quote
Old 03-31-2023, 09:29 AM   #2
OkieSnuffBox
Drives: '23 BRZ Limited
I think there was a similar thread in the GR section a while back and no one had found a solution.
But I agree 100% I'm not tall, but would like the seat to be lower.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
Old 03-31-2023, 10:25 AM   #3
Pat
Pat's Avatar
Drives: 2023 BRZ
You're not alone. Unfortunately the only good solution I know of is a different seat. You could cut out some of the foam, that that introduces other problems.
Could you find a seat from a ZD6 to put in the ZD8?
Old 03-31-2023, 11:27 PM   #4
gshopper
Drives: 2003 330i, 2019 BRZ (blue, with PP)
I just got a GR86. I'm tall (6-3), and it's a tight fit with a helmet. Just ordered this:https://www.amazon.com/dp/B0000AZ9KS...ectFromSmile=1
I plan to use it to stretch the seat springs over time. I will extend it between the seat and headliner (first put a firm pad over each end to spread the forces). Then raise the seat against the device so it will put pressure on the seat springs. Hopefully, over time, the seat springs will stretch and I will sit a little lower.
gshopper is offline   Reply With Quote
Old 04-01-2023, 12:02 AM   #5
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Have you tried this technique before on a different vehicle?
Originally Posted by humfrz
I'm old and lazy
Old 04-01-2023, 05:12 AM   #6
ACT86
ACT86's Avatar
Interesting idea. I’d worry about it denting the aluminium roof, but there may be a way to secure to a support up top. Keen to hear how it goes
Passenger seat height adjustment? cbf BRZ First-Gen (2012+) — General Topics 36 09-05-2022 06:32 PM
Seat bracket options to lower seat height dmarkey Cosmetic Modification (Interior/Exterior/Lighting) 13 04-02-2015 12:39 AM
Seat Height Adjustment Norman Tyler Scion FR-S / Toyota 86 GT86 General Forum 10 11-30-2014 07:26 AM
SEAT HEIGHT ZOMFGAARON Cosmetic Modification (Interior/Exterior/Lighting) 22 01-06-2014 08:41 AM
Height adjuster on passenger seat DriftEightSix Cosmetic Modification (Interior/Exterior/Lighting) 2 08-28-2013 09:06 AM
