Drives: 20’ GT86
P3 V3 OBD gauge vs Standlone Gauge
Hello guys,
I've tried to search for this topic but could not find anything conclusive. I'm debating whether I should go for a P3 V3 OBD gauge or a Standalone gauge (like a AEM Wideband UEGO) for AFR monitoring. I want to keep the look as OEM as possible but at the same time I want accurate readings. What's your opinion on this? |
#3 | |
Drives: 20’ GT86
Rust bucket enthusiast
OBD gauges are nice because there's a lot of info available. OBD gauges are also not good because they are limited to the sensors already existing, and they are using the OBD port that you may sometimes need for other things (depending on who you are). You can have the stock 02 sensors recalibrated to read lower in the af/r range with tuning software.
TL;DR- OBD2 gauges- less wiring, limited to stock parameters, multi-function, can only have 1 Standalone gauges- More wiring, nearly unlimited in function w/ appropriately matched sensors, typically limited to 1 or 2 functions, can have as many as you want
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block |
Drives: 2013 BRZ HKS Turbo
Depends on how critical AFR monitoring is for you. The OEM ECU already monitors AFR, and adjusts much faster then you can perceive. It's very difficult, and not very practical to read AFR while under heavy throttle. If you are just looking to make sure you are in the range of good AFR, the oem setup can be just fine with an OBD gauge (as noted, ecu should be adjusted to read richer AFR then standard). The OEM sensor is very accurate.
If, you are running a high strung high hp setup, it may be beneficial to have a redundant reading to the OEM, in that case, you'll want a second o2 sensor and gauge. (Assuming mild street/track setup) I'd suggest not monitoring AFR in real time at all, instead occasionally checking your STFT and LTFT to ensure all is well.
IG: @terboboost | Twitter: @terboboost | youtube.com/@terboboost | D-corp.co
#6 | |
Drives: 20’ GT86
I'm prepping the car and doing support mods but the end goal would be a turbo setup (looking at the greddy t518z) for around 300-ish WHP. I believe that's what you would call "mild". Running rich is not my concern, but running lean on high load scenarios is what I'm afraid of. My goal with having an AFR gauge is to serve as last defense in case something goes wrong with the tune/boost controller/vaccum/whatever. I will be installing a standalone boost gauge and a oil pressure gauge. But I feel like with just these two I don't really have an insight about what's going on inside the engine. |
| SOLD - P3 gauge multi gauge | iceblaze | Interior Parts (Incl. Lighting) | 2 | 10-23-2019 10:54 PM |
| AEM Oil temperature gauge and pressure gauge with pods. | mtsound | Engine, Exhaust, Bolt-Ons | 2 | 08-24-2017 12:55 PM |
| Fs: Gauge Pod and Autometer Boost Gauge | Juanito08 | Interior Parts (Incl. Lighting) | 1 | 06-29-2017 04:36 PM |
| Ultra gauge vs P3 digital gauge | Flat_4_Life | Forced Induction | 4 | 02-10-2016 03:29 PM |
| Defi Oil Pressure Gauge and Cravenspeed Flexpod Gauge Mount Install and Review | Tye300 | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 05-22-2015 12:48 PM |
