Old 03-06-2023, 10:53 PM   #1
gnarjunkie
Drives: '23 GR86, '17 BRZ
PP Brembo replacement pistons?
Has anyone tracked down a part number for a set of replacement pistons for PP Brembos? Had a dust seal go out on track and managed to melt one...
So far I've found a lot of replacement ones for STi Brembos but none for BRZ Brembos, not even from Subaru.
gnarjunkie is offline   Reply With Quote
Old 03-07-2023, 10:28 AM   #2
RedReplicant
Drives: None
RacingBrake sells them - https://racingbrake.com/subaru-6/
Rear piston on the 07-17 STI Brembo is the same as PP front and rear.
Zeckhausen sells just the boot and or seal, if you'd rather go that route. 40mm piston size.
https://www.zeckhausen.com/catalog/i...?cPath=82_1169
RedReplicant is offline   Reply With Quote
Old 03-07-2023, 12:42 PM   #3
gnarjunkie
Thank you!!
I'd read that people had thought they could be the same piston, but I wasn't sure if anyone had actually confirmed that or installed them.
The photo on RacingBrake had me 2nd guessing that as there are little imprints around the front face of the piston that aren't there on the ones I removed. Guessing maybe they used a generic photo though vs an actual photo of the part.
I need the boot and seals too, but the actual piston itself got melted so the first step has been figuring out if we can actually buy replacements or if we were going to have to buy a donor caliper or something.
Old 03-07-2023, 02:19 PM   #4
RedReplicant
Drives: None
Originally Posted by gnarjunkie View Post
Thank you!!
Yeah, RB doesn't sell the OEM 40mm pistons through their site, as far as I could find browsing around. I would email them and see if they'd be willing to sell you a set of 40mm OEM style pistons broken out from another kit of theirs (STI, EVO, etc).
Alternatively, email Zeckhausen and see if they can sell you OEM style pistons. They've always been SUPER helpful through email/phone for me.
Old 03-07-2023, 03:07 PM   #5
gnarjunkie
I actually would way rather have stainless steel pistons as the car is a full-time track car and it should help with heat dissipation. I was mostly thinking that the photos look different than the pistons I pulled out and that might indicate that the STi Brembo pistons were different than the BRZ ones.
If it's just a design difference due to being an OEM part vs a performance aftermarket part, I'm ok with that.
Old 03-07-2023, 04:36 PM   #6
RedReplicant
Drives: None
Yeah, it is for sure an aftermarket vs OEM thing.
2017+ PP Brembo pads replacement recommendations? lapsio Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 01-15-2023 07:36 PM
Project Mu 999 pads for Brembo brakes or brembo BBK. Still sealed in the box. $200 Jstyle Brakes, Suspension, Chassis 3 06-13-2022 12:23 PM
2017 BRZ PP Brembo Brake Pad replacement flamingdrumz97 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 12-15-2021 08:41 PM
BRZ Brembo rotor interchangable with STI Brembo? LatentWagen Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 08-05-2021 08:28 AM
replacement brembo cotter pins? Breadman DIY (Do-It-Yourself) Guides 7 02-12-2019 06:33 PM
