Old 03-06-2023, 05:03 PM   #1
jflogerzi
jflogerzi's Avatar
Part number for ARP Extended studs
I am still on the OEM Studs but the next time I go to swap my rotors which will be soon I want to put some ARP's. What's the longest that can be put on with having to remove hub to get them on
2013 Series 10 FRS #553
Old 03-06-2023, 06:08 PM   #2
kraftyone
kraftyone's Avatar
Drives: 2020 Subaru BRZ Limited PP
I did ARP 100-7729 they are 2.5" under head length. Didn't have to remove the rear hubs but I did have to loosen the 4 mounting bolts up some to wiggle the bolts in.
Sent from my SM-G986U using Tapatalk
kraftyone is offline   Reply With Quote
Old 04-21-2023, 12:00 AM   #3
eyeballs
Drives: '22 BRZ
In case ARP is out of stock (which was the case when I needed studs), 1320 performance has studs with the same specs as ARP.
eyeballs is offline   Reply With Quote
Old 04-21-2023, 06:46 AM   #4
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
I installed 2.5" all around without having to remove or loosen the rear hubs. I did need to cut the nipples at the end off with my Dremel to angle them in. Used this pocket then rotated the hub and was able to work them in one by one.
Once installed you can clean up sharp edges and make them look pretty.
WTB: Extended Studs Nick15Green Canada Classifieds 0 05-20-2020 06:21 PM
Extended studs - ARP, H&R or something else? re-animator Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 10-27-2018 07:10 PM
Brand New ARP wheels studs part number 100-7716 Gen3MR2 Wheels and Tires 3 09-21-2015 03:44 PM
WTB: ARP extended wheel studs mikep Canada Classifieds 2 05-22-2014 01:00 PM
non-extended wheel studs BadCompany235 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 05-14-2013 08:02 AM
