Old 02-27-2023, 05:41 PM   #1
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Delicious Tuning - Plug-n-Play Air/Oil Separator (AOS)
Hi All,
Delicious Tuning has developed a new Air / Oil Separator (AOS) that is plug-n-play with most all forced inductions applications. One of the primary concerns on the development of our AOS was to ensure that all emission control devices are working as intended and nothing has been removed from the vehicles breather system, (including the PCV). While we may not be the first to create an AOS, we saw a need for a simple plug-n-play system for almost all forced induction applications that will also work with naturally aspirated vehicles (for those looking to upgrade down the road). The number one reason to have an AOS is to remove the oil ingested by the engine that comes from the OEM breather system. Below are a list of reasons why this is a good thing.
Benefits of the Delicious Tuning AOS
- Reduces engine oil ingestion
- Reduces harmful cylinder hot spots
- Reduces pre-ignition and knock activity
- Reduces fuel vapor contamination
- Longer engine life expectancy
- Simple installation and maintenance free
- Fits most forced induction applications
- Retains OEM PCV and breather system
Model Year Compatiblity
2013 - 2020 Subaru BRZ (All LHD Models)
2013 - 2016 Scion FR-S (All LHD Models)
2017 - 2020 Toyota GT86 (All LHD Models)
2013 - 2020 Works Turbo Kit - Not Compatible
Included in Order
Air / Oil Separator (1)
PCV SAE 30R7 Hose (96 inches)
High Quality Clamps (8)
Digital Install Guide ​​​​​​(1)
Union 3/8-1/2 Adaptor (Edelbrock Only) (1)
For more details: 86 AOS
The Following User Says Thank You to DeliciousTuning For This Useful Post:
Joveen (02-27-2023)
Old 02-27-2023, 05:57 PM   #2
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
How does it empty or where is it drained to?
Originally Posted by humfrz
I'm old and lazy
Old 02-27-2023, 06:20 PM   #3
DeliciousTuning
It drains back into the crank case, instead of (partially) into your intake manifold (stock). So there is no need to empty it out.
For forced induction applications this is a pretty big deal, as there is a lot of blow-by from the heads into the intake manifold under boost.
Old 02-28-2023, 08:01 AM   #4
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
Is it me or does the drain hose rise above the drains low point in the picture? I guess it is just baffled inside since it doesn't look like it opens up to take a cart like a provent
Breadman is offline   Reply With Quote
Old 02-28-2023, 12:02 PM   #5
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
@DeliciousTuning,
Can we see a couple pictures of it installed with the strut braces in place?
And is there room enough for it with the Harrop installed?
Originally Posted by Mr.ac View Post
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 02-28-2023, 03:45 PM   #6
DeliciousTuning
As for the drain, I believe it is the angle of the picture and also that the protective sleeve make it look worse than it really is.
Originally Posted by FR-S2GT86 View Post
@DeliciousTuning,
Here are some more pictures with the AEM strut bar installed.
We have reviewed the Harrop Supercharger dimensions, location of hoses, and overall pictures. Based on this we are confident it will fit. If it does not we will offer a full refund on the kit.
We have tested it on multiple Edelbrock setups and it clears with plenty of room.
Old 02-28-2023, 05:01 PM   #7
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Yeah, it looks like it would fit.....if I didn't have my custom fuse-mounting shelf in place next to my homemade AOS.
You don't make one for the opposite side, do you?
Old 02-28-2023, 07:12 PM   #8
DeliciousTuning
Attachment 218832
I see what you mean. I think you need to relocate the fuse.
No we do not have an AOS for the other side. We did look on that side, but mounting it was a bit harder and it was a bit tighter on that side.
Old 01-15-2024, 07:34 PM   #9
86prime
Drives: 18 BRZ tS
Is this AOS CARB legal? I think it is since it's a sealed system retaining the OEM PCV valve, but can anyone confirm?
86prime is offline   Reply With Quote
Old 01-15-2024, 09:21 PM   #10
2.2Lude
2.2Lude's Avatar
It will not pass visual in CA. Anything that alters the PCV system is an automatic fail according to my SMOG tech buddies even if it technically reduces emissions. With that said if you do fail visual just remove it for smog then throw it back on. Doesn’t take much at all.
2.2Lude is offline   Reply With Quote
Old 01-17-2024, 11:05 AM   #11
86prime
Drives: 18 BRZ tS
See, that's where it's so unclear. Some pass it, some fail it (usually to protect themselves). I think there's a BAR email floating around saying it's legal. Also, see the BAR smog check manual appendix C:
https://www.bar.ca.gov/arsc/newslett...g-check-manual
Old 03-06-2024, 01:09 PM   #12
Diddy Kong Had A Dong
Diddy Kong Had A Dong's Avatar
Drives: 2018 Subaru BRZ Ts
Just installed mine! Very simple and straightforward install, took around 20 minutes even for me who likes to take my time and triple and quadruple check everything. I do have an STI PCV valve installed so I'll have to check back in a few weeks to see how it's doing since it is designed for the stock PCV valve
2018 BRZ tS WRB 493/500 | JDL UEL kit w/ gtx2860rs gen2
Diddy Kong Had A Dong is offline   Reply With Quote
The Following 2 Users Say Thank You to Diddy Kong Had A Dong For This Useful Post:
SOCON (04-29-2024), Wally86 (03-07-2024)
Old 03-10-2024, 11:49 PM   #13
FrickingReallySlow
Drives: 2015 FR-S
Which location does the AOS oil drain to in the crankcase? Does it drain to one of the heads?
FrickingReallySlow is offline   Reply With Quote
Old 03-11-2024, 12:08 AM   #14
It seems like it’s draining back down through the PCV valve into the crankcase
Delicious Tuning - Q&A EcuTeK ProECU Tuning and Maps DeliciousTuning Software Tuning 1213 06-17-2025 04:02 PM
PTUNING Plug and Play WMI (Water/Methanol Injection) System and ECUTek Tuning ptuning Forced Induction 71 02-27-2019 07:55 AM
Mann Engineering 2nd Quarter Tuning Days April 25th & 26th by Bill (Delicious Tuning) DesertFrs Northern California 14 04-24-2014 03:15 AM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 05:55 PM
FS: Oil Pressure gauge (includes Block galley plug for free!) True plug and play! Sportsguy83 Engine, Exhaust, Bolt-Ons 10 08-30-2013 10:53 AM
