| View the official forum sponsors list |
FT86Club Official Vendor
Drives: BRZ/FRS
(Open Box Deal) Ohlins Road & Track DFV Kit
Open Box Deal currently going on for the Ohlins Road & Track kit for the Subaru/Scion BRZ/FRS!
Please email us info@sakebombgarage.com for more details on special cash pricing for those who are local to the Bay Area! Features: - DFV (Dual Flow Valve) - Corrosion salt spray tested to ISO 9227 - 2 year warranty - Single bleed/Preloaded spring adjusters - Fully re-buildable w/dust-covers - Spring Rate: Front: 50 N/mm Rear: 50 N/mm Front (McPherson Strut): - Single bleed adjuster - Spring preload adjuster (20 mm lower than standard) - Coil Springs - Dustcovers - Use with original top mounts Rear (Conventional Shock Absorber): - Single bleed adjuster - Separate spring preload adjuster (20 mm lower than standard) - Coil Springs - Dustcovers - Use with original top mounts ![]() ![]() ![]() |
| Tags |
| brz coilovers, frs coilovers, ohlins, road & track, sakebomb garage |
| Ohlins Road & Track $600 | eron | Brakes, Suspension, Chassis | 12 | 05-15-2019 09:32 PM |
| Ohlins Road and track coilovers | Lithium | Brakes, Suspension, Chassis | 7 | 07-29-2017 04:20 PM |
| Ohlins Road & Track - settings (clicks) for street/track/ax | dp1 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 39 | 06-27-2016 09:36 PM |
| Ohlins Road and Track | createluck | Brakes, Suspension, Chassis | 2 | 04-21-2016 01:36 PM |
| Ohlins Road & Track | enivid | Brakes, Suspension, Chassis | 9 | 03-12-2016 07:58 AM |
