Old 02-12-2023, 08:34 PM   #1
happyshlappy
Drives: Brz 2013
Glitter in oil?
Did an oil change today, just passed 85k miles.
Noticed all this brass glitter in the pan? Time to source a new motor?
Car hasn't had any issues. Oil is always at it's right level and from what I can tell no pressure or temp issues. I just commute with it.
I ordered an oil analysis kit already so we'll see what that says.
https://imgur.com/a/i5QbSOw
happyshlappy is offline   Reply With Quote
Old 02-12-2023, 09:53 PM   #2
nissanfanatic
nissanfanatic's Avatar
Drives: 2023 BRZ
If you still have the oil filter, I'd cut it open and inspect the filter media for glitter. A bit quicker than an oil analysis and if your engine is indeed shedding metal at alarming rates, some should be captured in the filter.
https://www.amazon.com/Foghorn-Power...dp/B097QGM2ZQ/
I have that exact cutter and it's decent. In a pinch, tin snips work as well but it's def not as clean/easy as the proper tool.
nissanfanatic is offline   Reply With Quote
Old 02-12-2023, 10:04 PM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
glitter is never good.
Old 02-12-2023, 10:34 PM   #4
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
I recommend gloving up before playing with used motor oil.
Originally Posted by humfrz
I'm old and lazy
Old 02-13-2023, 06:46 AM   #5
KillerBMotorsport
KillerBMotorsport's Avatar
^ this right here. Will tell you if you have a big problem on your hands.
If you took a sample during the drain, you can send it off for analysis, but samples taken after don't typically give good results vs catching a sample of HOT oil during mid-drain. If the filter is good, an analysis will tell you if you have normal or excessive wear.
KillerBMotorsport is offline   Reply With Quote
Old 02-13-2023, 08:01 AM   #6
Grady
Grady's Avatar
Especially if you do not get it all off before coming home to your wife!
Old 02-13-2023, 08:59 AM   #7
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Originally Posted by Mr.ac View Post
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 02-13-2023, 10:34 AM   #8
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Old 02-13-2023, 11:17 AM   #9
happyshlappy
Drives: Brz 2013
Here’s the filter cut open. Don’t see any glitter in here, just chunks from the cut filter wall. https://imgur.com/a/Hfg9dAg
Old 02-13-2023, 01:49 PM   #10
nissanfanatic
Drives: 2023 BRZ
Cool, so you still have the filter.
Ok you won't really be able to see much like that. The oil flows from the outside of the filter to the center, so you need to extract that accordion filter media from the housing to be able to see in between those pleats.
This picture shows what you should end up with. I use a razor blade to cut the cardboard or synthetic media and then pull it away from the center filter support structure.
Pro-tip from there, compress the accordion media together, wrap in a shop towel, and compress it in a vise to squeeze all the oil out. That makes it easier to see anything when you open up the pleats.
Old 02-13-2023, 02:53 PM   #11
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Sorry to hear this. As others have said metal flake belongs in garish paint jobs. In oil it is the tarot card of death. The engine may not know it yet. But it is dead.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 02-13-2023, 02:54 PM   #12
Not that I have done it in years nor ever plan to do it again but that is genius. So simple but effective.
Old 02-13-2023, 03:26 PM   #13
Capt Spaulding
Persona Non Grata
Wow. I had never thought of that. Truthfully though, I have never in my life dissected an oil filter. On the few occasions when I’ve had metallic debris in the drain oil, I’ve just pulled the engine apart. I’ve never been surprised with good news.
Old 02-13-2023, 04:53 PM   #14
happyshlappy
Drives: Brz 2013
I pulled it out but there wasn't really any glitter at all, much much less than was in the drain pan. Maybe it was some debris or something in a dirty drain bucket, I didn't inspect it before I started draining oil.
how do you get rid of glitter JLMtm Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 26 01-10-2013 03:32 AM
