Drives: Grand Vitara
Window stck open and no key
I have just purchased a salvaged 2013 86 and the car did not come with any keys at and the windows are partially down and I want to "wind" them up so its rain proof.
I have not found a wiring diagram yet to try and work out how the windows work, but I am hoping someone here may have a simple solution they can share. How can I close my windows when I do not have a key to turn the car on? (i.e. bridge battery to fuse for windows so something similar) Thanks |
Drives: 2015 BRZ WRB
contractor garbage bag and duct tape
ProCrastinationConsultant
9v battery to the window motors in the door. one way raises them, 1 way lowers them.
just need to pull the door panels, which considering the vehicle is a salvage with no keys, you've got a lot of panel pulling in your future anyways to replace/re-code modules.
| The Following User Says Thank You to soundman98 For This Useful Post: | villainous_frx (02-05-2023) |
#4 | |
Thanks Is there more info on the replace/re-code modules and which ones are needing to be done |
| Switched out window regulator. Now my window decided that this will be its max height | kev0 | Issues | Warranty | Recalls / TSB | 13 | 07-21-2021 09:10 PM |
| Window Shatter / Fracture - passenger small triangular window | btune | Issues | Warranty | Recalls / TSB | 5 | 12-25-2016 02:14 PM |
| Drivers window grabbing window seal and pushing it up. | stockysnail | Issues | Warranty | Recalls / TSB | 22 | 12-22-2015 01:08 PM |
| Window Scratched by Window Motor / Lifter? | tomkozski | Issues | Warranty | Recalls / TSB | 22 | 05-31-2014 07:25 AM |
| squeaky window due to window rubbing against rubber at the top | tracerit | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 5 | 08-10-2013 05:34 AM |
