Old 01-30-2023, 08:05 PM   #1
APEX Race Parts
FT86Club Official Vendor
APEX Race Parts's Avatar
Drives: Launch-Year Whiteout FR-S
► APEX | Flow Formed Lightweight 5x100 86/BRZ Wheels - Built to Perform
APEX Flow Formed 5x100 86/BRZ Wheels
Since 2007, APEX has been the go-to wheel for track enthusiasts and club racers looking for the perfect balance between strength, weight, and cost. APEX wheels address the concerns of more and more car enthusiasts: long term durability, optimized chassis-specific fitments, and enhancing performance. Our flow formed 5x100 wheels optimized specifically for the 86/FRS/BRZ community are designed to be strong, lightweight, and functional, and to top it off they all clear the factory Performance Package/TRD Brembo brakes as well as a variety of aftermarket BBK’s. Whether you enjoy your car day-to-day on the street or you're a hardcore track enthusiast/racer who needs wheels that can withstand track abuse, we have you covered.
➡︎ Perfected 86/BRZ chassis-specific fitments
➡︎ Clear factory Performance Package & TRD Brembo brakes
➡︎ 100% OEM compatibility, no extra hardware required
➡︎ Unbeatable warranty & 50% replacement program
Designs, Finishes, & Specifications
Fitments: 17x9" ET42 & 17x9" ET35
Weight: 17.8 lbs & ~18.3 lbs
Bolt Pattern: 5x100mm
Center Bore: 56.1mm
VIA Registration: VIA-23-1700
MSRP: $304 ea.
Fit Matters
The right solution for every application. An optimized chassis setup begins with the right wheel and tire fitment, and without model-specific attention, maximum performance is compromised. We offer the ARC-8 in several different widths, offsets and diameters to give drivers a choice between straightforward bolt-on fitments to more aggressive specialty fitments depending their goals for the car. Daily drivers and professional racers don't have the same needs, so why should they be forced to buy the same exact fitment?
These wheels were developed exclusively for the 86/BRZ chassis in a square configuration which promotes a neutral handling experience while allowing drivers to efficiently rotate wheels and tires on all four corners of the car. This dramatically reduces the cost of tires over time. Corner carving & track enthusiasts: this is your wheel.
Massive Brake Clearance
Engineered to clear factory Brembo brake options, as well as a variety of aftermarket BBK’s. APEX wheels are specifically engineered to clear all OEM brake calipers including the Performance Package/TRD Brembo brakes. Our wheels are targeted at the serious performance-minded owner knowing many will elect to upgrade the basic OE caliper and disc setup as they get more serious with mods. If you do go with an aftermarket big brake kit (BBK), most big brake kits that clear 17” wheels will fit behind our low profile spokes without spacers, although some applications may need a thin spacer due to the added width of aftermarket calipers.
Confirmed BBK clearance on our 17x9.0” ET42 ARC-8 wheel include: Stoptech ST40 328mm, Essex-AP Sprint 4 pot 325mm, Essex-AP Endurance 4 pot 299mm, AP Racing 4 pot 330mm, Wilwood's kits, RacingBrake 4045, STi 4 Piston, 300ZX 4 pot, Alcon 4 pot 334mm, Sparta 4 pot 355mm kit (3mm spacer is recommended), Tarox B32-6 326mm kit, RR Racing Stage I through IV Competition kits. Wheels shouldn’t limit your choice of factory or aftermarket big brake kits, and big brake kits shouldn’t force you to run heavier, oversized wheels. View our fitment guides to confirm brake clearance, or contact us if you don't see your setup listed.
Weight Optimized
We conducted extensive Finite Element Analysis to reinforce high-stress areas and to remove material where it didn’t improve strength. The end result is a flow formed wheel with an ideal balance of strength and weight.
True VIA - JWL & Beyond
Many companies promote their wheels as being certified by the VIA when they actually aren’t. That’s like using the USDA logo on food without permission. APEX wheels get officially tested and registered by the VIA in Japan, and we have the proof to back it up. Japan’s JWL is a standard for wheel load ratings. Our wheels exceed those ratings. Most manufacturers only meet the minimum, while some even fall below—yet they still claim to be JWL. Always verify load ratings before you buy. Learn more about VIA and JWL
Additional Features
Hub Centric - All APEX 86/BRZ wheels with a 5x100mm bolt pattern are purpose built featuring a 56.1mm center bore. No centering rings required.
Center Caps - All wheels come with our gloss Black APEX caps included, and optional gloss red APEX caps are also available. We also design our 86/BRZ wheels to be interchangeable with the OE cap for enthusiasts seeking a clean factory look.
Hardware - APEX wheels can be used with all OEM mounting hardware, proper aftermarket hardware and wheel spacers. Wheel locks and stud conversion kits also work perfectly.
TPMS - All APEX wheels accept OEM and aftermarket Tire Pressure Monitoring Sensors and standard fit valve stems. If your vehicle isn’t equipped with sensors or you choose to bypass them for your track/race car, then select from our metal stems available in multiple finishes.
Unbeatable Support
Warranty: All APEX wheels come with a lifetime structural warranty and 1 year finish warranty, so you can be confident in your purchase. Learn more
Replacement program: Let’s face it: Whether you are a weekend warrior practicing at the track, a club racer pushing the limit for a podium finish, or your daily commute involves crater-ridden minefields known as city roads, mistakes happen and parts will be damaged along the way. We are not really a performance company if we sell wheels in a way that penalizes the pursuit of driving at the limit. For this reason, we stepped up and created a program to significantly reduce the costs of properly maintaining a set of wheels by making replacements extremely affordable.
Our unique APEX Wheel Replacement Program offers eligible customers replacement wheels at 50% off our standard prices. Learn more
Chassis-Specific Fitment Guides
We know what fits. From direct bolt-on to all-out race fitments and everything in between. We've street and track tested extensively to save you the trial-and-error. View our fitment guides.
APEX Wheel Gallery
Click to Order Now
Questions?
Call: 925-245-0773
Email: expert@apexraceparts.com
Web: www.apexraceparts.com
Hours: M-F 9a-5p PST
APEX Race Parts is offline   Reply With Quote
The Following User Says Thank You to APEX Race Parts For This Useful Post:
Clipdat (03-29-2023)
Old 01-31-2023, 02:41 PM   #2
APEX Race Parts
Reserved.
Old 03-01-2023, 10:37 AM   #3
Tatsu333
Drives: 2020 BRZ Sport Tech RS
Originally Posted by APEX Race Parts View Post
Reserved.
I see what you've done there...
Looking forward to any upcoming news on the flow-formed lineup!
Tatsu333 is offline   Reply With Quote
Old 03-29-2023, 08:13 AM   #4
Kulebrero
Drives: GR86
Is there anyway to get these in 18x9, ET40-42, 5x100?
Kulebrero is offline   Reply With Quote
Old 03-29-2023, 12:03 PM   #5
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
APEX is killing it right now! Wheel game on point!
Originally Posted by humfrz
I'm old and lazy
APEX Race Parts (03-29-2023)
Old 03-29-2023, 07:38 PM   #6
APEX Race Parts
At the moment we aren't offering our ARC-8 in any 18" fitments for 86/BRZ. We are looking to grow our JDM-specific catalog as a whole though, so keep an eye out!
In the meantime, we are offering our VS-5RS and SM-10RS in 18x9" ET42 fitments for 86/BRZ.
Old 03-29-2023, 08:51 PM   #7
Kulebrero
Drives: GR86
I must be using the wrong site or something. The only 18x9 I see is the EC-7R +35. I would take it, but I really need something in the +42-45 range.
Old 03-31-2023, 11:10 AM   #8
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
Any EU distribution ?
autoracer86 is offline   Reply With Quote
Old 03-31-2023, 01:21 PM   #9
APEX Race Parts
Our site may not be displaying the new wheel offerings privately. I did PM Kulebrero about this, but if anyone else runs into a similar issue definitely shoot me a PM.
We do offer international shipping. We also have a few international dealers that we work with as well. If you send me a PM we can get you sorted!
autoracer86 (03-31-2023)
Old 05-12-2023, 08:53 AM   #10
nissanfanatic
nissanfanatic's Avatar
Drives: 2023 BRZ
@APEX Race Parts I've been watching for updates on your site for the 17 x 9 ET42's. Would you happen to have any more info on ETA? Was watching when it was April, and that got pushed to May...
nissanfanatic is offline   Reply With Quote
Old 05-12-2023, 01:43 PM   #11
APEX Race Parts
As more people have gotten their hands on Gen 2 cars, we've been watching our 17x9" ET42 get scooped up faster than ever. In one of our wheel finishes, we essentially had an entire restock worth of wheels pre-sold through backorders.
We are expecting some more of our Satin Black and Satin Bronze at the end of May. The next Anthracite batch is due in July.
If you haven't already, I recommend placing a backorder. Once we get new wheels in, yours will ship out automatically.
► APEX | Flow Formed Lightweight 5x100 86/BRZ Wheels - Built to Perform APEX Race Parts Wheels and Tires 51 03-22-2023 11:45 AM
► APEX | Fully Forged Lightweight 86/BRZ Wheels APEX Race Parts Wheels and Tires 59 07-20-2022 12:20 PM
► APEX 2020 Spring Sale - 10% OFF Lightweight 17” ARC-8 Wheels APEX Race Parts Announcements, Contests, Giveaways 4 05-05-2020 04:04 PM
New Flow Formed DOSS WHEELS! 18x9.5 +35 5x100 Rev Motion Wheels and Tires 13 06-02-2016 06:20 PM
