Old 01-20-2023, 05:52 PM   #1
RedReplicant
Drives: None
STI Rear Brembo
Is there any reason that a ~2017 STI rear Brembo caliper wouldn't interchange with a PP rear Brembo? We already know the bolt up to the car fine.
They both use the same Centric rebuild kit for a 40mm piston
https://centricparts.com/part-detail/14335031
They also both use the same DBA dual drilled rotor
https://www.counterspacegarage.com/dba-4000-brz-pp-rear
https://www.rallysportdirect.com/par...otor-pair-rear
This seems to indicate that they're the same offset and the same piston size so there would be no balance change or alignment issues.
RedReplicant is offline   Reply With Quote
Old 01-21-2023, 04:32 PM   #2
RedReplicant
Drives: None
Gonna find out ... for science. I ordered a set of reman'd Powerstop calipers and a Centric rebuild kit for each from RockAuto for $115/caliper including $48 core charge each. $15 a pop for the rebuild kits.
Going to measure the pistons when they get here, if it is what I expect (40mm) then I'll disassemble, drop them at my powdercoater for red w/ Brembo logo, and put the Centric seals in them.
Old 01-26-2023, 02:53 PM   #3
RedReplicant
Drives: None
They're the same. I assume the confusion comes from people measuring the front of the piston where it contacts the pad, which is 36mm on both the PP and STI rear, or because the orange 04-07 STI rear calipers were 36mm pistons. Pistons are 40mm on both 08-17 STI rear and PP rear.
This is a picture of some, just to help illustrate. The dust seal fits into the groove and effectively hides the full piston size.
Old 01-26-2023, 10:02 PM   #4
Spawn_Of_Creation
Human
Drives: 2015 BRZ Black
Is the bleed valve still on the top side?
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
Spawn_Of_Creation is offline   Reply With Quote
Old 01-27-2023, 05:57 AM   #5
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Pretty sure ALL bleed valves are on the top for physics reasons.
Old 01-27-2023, 08:28 AM   #6
Spawn_Of_Creation
Human
Right, but what i mean is the caliper on the same front/back side of the rotor? The BRZ/FRS/GT86, the caliper is on the rear side of the rear rotor. If the sti caliper is on the front side of the rotor originally, then the caliper will be flipped about 90ish degrees so the valve might be on the bottom side if installed on our platform, assuming you can't just flip the side of the car.
Old 01-27-2023, 11:06 AM   #7
RedReplicant
Drives: None
Yes
Old 01-27-2023, 12:47 PM   #8
RedReplicant
Drives: None
STI caliper uses M10x1.5 38mm bolts instead of M10x1.25 38mm bolts, so watch for that if you're coming from normal sliding calipers or aftermarket rear calipers.
Rotor is a Centric PP blank, it is centered in the caliper.
Centric 40mm BRZ PP seal laid over the piston, matches
Old 01-27-2023, 04:53 PM   #9
gt5759
Drives: 2017 BRZ
Nice find!
gt5759 is offline   Reply With Quote
Old 01-27-2023, 04:56 PM   #10
RedReplicant
Drives: None
Originally Posted by gt5759 View Post
Nice find!
Thanks, I'd kinda worried about being called out on them for TT5 but I think that would be extreeeemly nitpicky and I think they fall under the functionally identical allowance anyway given that the difference between the two comes down to paint color.
Old 01-27-2023, 05:28 PM   #11
gt5759
Drives: 2017 BRZ
Originally Posted by RedReplicant View Post
Thanks, I'd kinda worried about being called out on them for TT5 but I think that would be extreeeemly nitpicky and I think they fall under the functionally identical allowance anyway given that the difference between the two comes down to paint color and the mounting bolt thread pitch.
Absolutely. No piston count change or piston diameter change, they bolt up factory and use a stock rotor. Its just a house brand caliper instead of a brembo name. No one would ever protest that.
Old 01-27-2023, 05:57 PM   #12
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Should be sticky. Nice find. I was going to replace rear calipers this year, may have to go this route.
Old 01-27-2023, 06:23 PM   #13
RedReplicant
Drives: None
It's too bad the STI front is 40/46, there are cheap remans of those too. Still got pay the steep PP front caliper tax.
Old 04-05-2023, 06:22 PM   #14
alphasaur
friendly
Drives: 17' 86
It's too bad the STI front is 40/36, there are cheap remans of those too. Still got pay the steep PP front caliper tax.
why not go ats front calipers? Same size pistons as PP kit.
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
WTB: 2017+ BRZ OE Brembo Rear Brake Rear Right artongdou Want-To-Buy Requests 0 08-18-2019 04:24 PM
Brembo GT BBK Front and Rear ThatBlueBRZ Canada Classifieds 3 05-03-2017 11:53 PM
Brembo Rear Calipers - from '05 WRX STI AyJay Brakes, Suspension, Chassis 7 05-14-2014 10:50 AM
05 REAR STI BREMBO CALIPERS subyboy Brakes, Suspension, Chassis 19 04-15-2014 07:07 PM
F/S 05 STI REAR BREMBO CAPLIPER subyboy NY / NJ / CT / PA 16 12-26-2013 12:46 PM
