Old 01-19-2023, 04:13 PM   #1
alex87f
Meow
alex87f's Avatar
Drives: GT86 (now sold)
Chasing a suspension noise
Hey guys,
My 86 has been giving me a weird, sharp “tung” from the front suspension, which I’ve been unable to track down so far. It’s fairly random, loud enough that you’d probably be able to hear it from outside the car, and seems to mostly happen when hitting speed bumps unevenly with the front axle.
The only way I’ve been able to hear it more consistently it is by turning downwards and to the right into my driveway, although it sounds milder than when hitting a bump.
The car is a 13 with around 70k. No real track use, was a DD up until a few months ago.
My guess is either shot drop links or -less likely- ARB bushings. Is that a good guess?
Regards,
Alex
alex87f is offline   Reply With Quote
Old 01-19-2023, 09:26 PM   #2
Grady
Grady's Avatar
What top hats do you have?
Old 01-23-2023, 06:18 AM   #3
alex87f
Meow
alex87f's Avatar
The suspension is 100% stock.
Old 01-23-2023, 08:03 AM   #4
Dake
Dake's Avatar
If the sound is as described, it sounds like something binding and releasing which is weird. The top hats on early models are notorious for failing, but they make a metallic rattle over low speed bumps (like lane reflectors).
Dake is offline   Reply With Quote
Old 01-23-2023, 03:18 PM   #5
MJones_RB
MJones_RB's Avatar
Sound like where your springs seat on the strut it's binding. Check to make sure you have some space between the end of the spring and the lip of the seat. Good luck!
MJones_RB is offline   Reply With Quote
The Following User Says Thank You to MJones_RB For This Useful Post:
alex87f (04-02-2023)
Old 01-24-2023, 08:40 AM   #6
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
I'd check the spring on that side like previously mentioned, also check that the 8 bolts holding the aluminum skid tray under the engine are all tight.
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
The Following User Says Thank You to Opie For This Useful Post:
Old 04-02-2023, 12:38 PM   #7
alex87f
Meow
alex87f's Avatar
Thanks. I just ordered a set of OEM drop links & ARB bushings for the front end. Will also check that part of the strut assembly. Should it be binding, will I be able to move the spring without disassembling everything?
Also, how far away from the lip should the spring be ?
The Following User Says Thank You to alex87f For This Useful Post:
MJones_RB (04-03-2023)
Old 04-03-2023, 01:26 PM   #8
MJones_RB
MJones_RB's Avatar
Here you go.
The Following 2 Users Say Thank You to MJones_RB For This Useful Post:
alex87f (04-03-2023), norcalpb (04-03-2023)
Suspension noise after J02? alex87f Issues | Warranty | Recalls / TSB 13 03-21-2021 12:11 PM
Seriously - more suspension noise Scoob Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 05-23-2018 01:43 AM
Suspension noise? HubertK Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-09-2017 08:50 PM
Stock suspension noise lite Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 06-12-2016 05:55 PM
Suspension: Chasing Gremlins in the Front Passenger Wheel Adeel Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 10-02-2015 12:08 PM
