Sleeper
Drives: WRB_BRZ
Uneven ride height, stock suspension
I have been noticing the rear left sitting lower than rear right for some time now, not much but definitely noticeable. So I raised the car on stands all 4 corners, perfectly flat ground even used a level to make sure the bubble is at dead center all 4 corners. Removed the wheels off, started measuring multiple times every corner, fender to hub and rotor. Front left and right match as expected. Rear left hub assembly measures .25inch higher then rear right, that means with wheels on, rear left is .25inch lower than right. Pulled rear shocks out, measured them, they are perfectly even. Now remeasured(In different ways I can imagine) the fender to hub/rotor without shocks and still the left hangs .25 inch higher then right. So spring rate is a non issue.
Did I hit something hard and bend a suspension component? Any guesses what could it be? I can fix this problem by getting coilovers and adjusting rear left coilovers .25 inch longer than rear right and make the ride height even all 4 corners but I would like to really address the root of this issue. Thanks in advance. Edit: also the alignment is clean, no pulling and no uneven tire wear. "Scratchingmyhead.gif" |
Fenders aren’t necessarily even left to right, measure the pinch welds and I bet a lot of the discrepancy goes away. Having an even alignment points to this maybe not being a suspension issue.
Also make sure springs are fully seated in their pockets on the dampers. |
Señor Member
.25" is not a huge amount. I totally get that it would bug you but at the end of the day I wouldn't worry too much about a small difference.
That said, as mentioned check how the springs seat and maybe even swap the left and right springs to see if the height difference changes side.
1974 TA22 Celica
2013 86 GT |
Stock suspension usually isn't perfectly even. 1/4 inch is maybe a little more than usual but I've definitely seen it.
- Andrew |
#5 | |
I have the same issue with my SS1 coilovers on my 23 BRZ. Driver's rear has 15mm more threads showing to achieve a level height. Is this, ok? I don't want to hurt the performance of the setup if there is an issue. |
#6 | |
![]() If you google for corner weights on a stock or modified BRZ/86 you'll see numbers all over the place depending on driver weight, how much fuel, whether swaybars are still attached, what day the car was built (jk), and so on. - Andrew |
#7 | |
Drives: 22 BRZ limited
LMGTFY
Drives: 13 FRS, 91 Miata
Weather or not you let one go in the car or got out before hand.
| DIY: Adjusting ride height on coilover suspension | justinco | DIY (Do-It-Yourself) Guides | 5 | 08-13-2018 12:50 PM |
| Which coilover sets don't reduce suspension travel when lowering ride height? | Infinity | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 04-28-2018 04:14 AM |
| Squeaking / Creaking rear suspension with low ride height? Suspension pros welcome! | mothespaceman | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 08-14-2015 05:06 PM |
| BRZ vs 86 stock ride height | Moe | AFRICA | 2 | 11-21-2013 08:35 AM |
| Ideal ride height for best suspension geometry? | Hachi86Roku | Tracking / Autocross / HPDE / Drifting | 8 | 11-19-2013 07:46 AM |
