Drives: 2015 Firestorm 08/05/15
CAR IS SOLD: 2015/FRS/ Firestorm Red C7P / 15477 original miles
Immaculate condition, never smoked in, original owner since new in March 2015.
Garaged kept. Not looking to part out or trade at this time. Located in Rockmart, Georgia 30153. $25,000 no lien, clean title, no crashes or scratches. Feel free to carfax. Quick TLDR: 2015 FRS G500X Turbo, Dyno tuned by Doug Wilks of DBW Motorsports in Atlanta, Ga. 305 hp/267 torque on 93 octane. 350 hp/280 torque on E-85 at 11 lbs boost. Latest SBD G500X turbo kit with upgraded braided oil/coolant lines/ intake and filter. Latest delicious tuning Bluetooth E-85 flex fuel kit. Oem performance package Brembo brake kit. Oem performance package suspension. SouthBend stage 2 clutch, Y58 oem differential. Every component bought new and installed by myself. Car was my retirement reward to me in 2015. Only selling because I can no longer drive a manual due to health issues. Car has zero problems. Car usage: Driving in the mtns with my grandson on clear days. Strict maintenance schedule, oil changed 12 times since 2015. Tried to do it on average of 2,000 mile increments, sometimes more frequently. Turbo installed 1/27/2020. 00/20 w Mobil 1 before turbo and 00/40 w after turbo install. Trans, diff fluid changed twice annually with Motul 300. Brake, clutch fluid flushed twice annually with motul 600 Car has been garaged from day one and never been left outside overnight. Never been driven in the rain. Exception would have been when car was new at dealer before my purchasing. Brakes: I installed OEM performance package Brembos brakes, including all new Brembo brake shields and hardware. 2019 TRD ABS module, stop tech brake lines and 993 Porsche front brake duct mod . Spare tire replaced with oem spare to clear Brembo brake kit installed. All oem brakes and hardware come with the car as well. Diff, I installed a new Y58 diff ordered from a 2019 TRD 86 new. Suspension: 2019 TRD Performance package dampers on Hotchkis springs. Hotchkis front sway bar oem rear bar. All oem bars and Hotchkis rear bar, with oem struts and springs come with the car. White line steering rack bushings, rear diff bushings, SPL titanium rear lower camber arms, spl rear toe arms. TRD rear trans bushing. Car only ever aligned by Gabe the wizard at Gran Turismo East in Atlanta, Ga Transmission is stock with M-Tech spring and ball bearing conversion for smooth actuation. Clutch: Verus clutch ball and forged pivot arm installed, upgraded 2017 throw out bearing. SouthBend stage 2 daily clutch and matched new flywheel with ARP flywheel bolts. All installed by me and broken in per SouthBend warranty requirements. Installed 500 miles before turbo at approximately 13,000 miles. Engine: internals stock unopened. Exception is Oil pan for turbo installed along with a Killer Beez oil pick up tube with Greddy windage tray installed by me at turbo install. Oil cooler, oem WRX/Forrester hard piped from block to cooler as oem. Plugs are new oem installed at turbo install. Coolant has been changed 4 times. All new water and heater hoses, tensioner pulley , idler pulley, serpentine belt replaced , routine maintenance 12/01/2022 by me. 2019 Red aluminum intake installed at turbo installation. Berk High flow cat front pipe, Turbo manifold, down pipe, invidia overpipe are cerakoted 2000 degree plasma silver as well as exhaust side of turbine housing. Down pipe and overpipe are DEI titanium and ATP titanium turbo blanket for proper heat mitigation. All electrical components, wires, and panels in and around turbo area are treated and shielded for heat dissipation as well. Tune: Ecutek tuned by Doug Wilks of DBW Motorsports , Atlanta, Ga. 93/E85 tune with fail safes per Doug. 93 octane -305 hp/267 torque. E85- 350 hp/280 torque at 11 psi boost Fail safe it at 5 psi boost. Oem intake, sound tube and hardware are included with the car. Fuel system: velox fuel starvation door installed in tank along with AEM high volume fuel pump and harness. Oem pump comes with the car as well. Car is tuned on stock injectors per Dougs tune for street drivability and smoothness. 65 percent duty cycle. There is still 35 percent head way on stock fuel system. A conservative tune of 11 psi max is used. Ecutek dongle with blue tooth included with the car. Current Ga. Emissions inspection up to date. Never had a problem zero oil leaks. Only time the engine has ever been red,ined was during Dyno tuning. Drive line has never been abused, I am not hard on my equipment. It’s set up as an everyday driver, mtn cruising, or occasional track day. Exhaust: Berk high flow front pipe cat into an Invidia Q300 cat back with Helmholtz resonator. Zero drone in cabin. Exhaust note is deep quiet M3 type sound no ricer Tin can noise maker. Clutch: SouthBend stage 2 oem SouthBend flywheel with APR flywheel bolts. Installed 500 miles before turbo install. Broken in per exacting instruction for south bend warranty. Interior: stock with added 3 pillar, Prosport JDM analog/ LED gauges. ( AFR, boost, oil temp, and oil presure gauge mounted on steering column bezel). Rear shelf brake light (spaceship) removed and relocated Lexus style upper roof rear hatch brake light installed. Rear shelf recovered in leather matching red stitch upholstery. Rear seat tunnel cover as well. Flat bottom oem style steering wheel. Oem wheel is included. Sirius Xm satellite radio with oem antenna and harness. Lights : complete Diode Dynamics LED light conversion. Headlights, DRL, Fog, Rear, interior, and trunk. 4th center led rear brake/ running light at lower valance. Body: zero scratches and dings. Excellent condition, paint correction (I logged 23 hrs) and G-Tech crystal C-1, C2, V3 applied by me. No accidents or damage , feel free to carfax Oem TRD color matched rear spoiler, front spoiler filler, Beat Sonic rear color matched roof spoiler. Rear lower valance and oem mud flaps, ProTekt front bumper protection skid plates installed on oem front bumper all done my me. Car has front camera and rear back up camera as well. 2015 FRS base , at the time of this add its 15,477 original miles. Firestorm C7P red color. Manual 6 spd. All books and documents with maintenance records. Original unopened zero leaks at front timing cover and normal prone areas. Wheels and tires: Michelin Pilot Sport 4s, 235/40/18 fronts 255/35/18 rears. Approx 9000 miles on wheels and tires. Wheels are VMR 705’s, 18 x 8.75 Hyper Silver or the same wheels as XXR 535 wheels sold in the US. Included is a 5 the wheel in the box for a spare. Oem wheels and tires in perfect condition approx 5500 miles on them come with the car as well. Extras: Verus hood vents with rain guards, color matched C7P Firestorm red, all hardware. I never got around to installing them. All oem bulbs rear stock lower control arms, toe arms and everything that I took off car to put it back stock co e with the car. The exception is the front cat pipe and oem cat back exhaust. Feel free to contact me for more info. Thx Steve Last edited by sroby; 01-18-2023 at 11:33 PM. Reason: Adding a pic typo on miles it’s 15,477 |
Forgot to add it comes with Shorai 5 lb battery with charger and kinetic engineering battery minutes
Be Kind
Drives: 2020 86
Not looking to buy but that has to be the cleanest turbo install I've ever seen.
| The Following User Says Thank You to Wally86 For This Useful Post: | sroby (12-31-2022) |
Thanks partner. Retired OCD Air Force aircraft mechanic of 27 yrs. Can’t help myself.
| The Following User Says Thank You to sroby For This Useful Post: | Wally86 (01-02-2023) |
agree. Beautiful car. GLWS!
2013 Series 10 FRS #553
| The Following 2 Users Say Thank You to jflogerzi For This Useful Post: | sroby (01-08-2023), whataboutbob (01-01-2023) |
AutoX-10/10ths every run
That's an amazingly clean (build and maintenance) car. GLWS.
| The Following User Says Thank You to whataboutbob For This Useful Post: | sroby (01-08-2023) |
Frs is sold
Unit is sold. Admin can you please delete the sales add. Thx Steve
Admin please delete the car is sold.
| FS: 2015 Scion FR-S – Firestorm – 6MT, ~79K miles, Rebuilt title | Dave-ROR | Cars for Sale/Trade | 10 | 03-28-2020 11:58 AM |
| FS: 2013 Original Headlights (Left and Right) <5K miles | firestormriot | Exterior Parts (Aero, Lighting, Etc.) | 4 | 07-12-2018 04:16 AM |
| FS: 2013 Original Sidemarkers (Left and Right) <5K miles | firestormriot | Exterior Parts (Aero, Lighting, Etc.) | 4 | 05-10-2018 06:50 AM |
| FS: NJ / 04 WRX STI / CLEAN TITLE / 26,xxx ORIGINAL MILES | Ellsworth007 | Cars for Sale/Trade | 0 | 03-20-2015 04:11 PM |
