Old 12-21-2022, 06:12 PM   #1
BrzDom
Drives: 2013 Subaru BRZ
Knocking/rattling noise when engine is warmed up???
Hi, I bought a '13 BRZ yesterday and when the engine gets warm it starts tickling, and knocking. After research, I think it could be the vacuum pump, fuel pump, valve proble or rod knocking? Some say it's normal. Does anyone have had this issue or could know what's up with it? I've posted videos on Reddit so I'll just link them below. Thanks
Warmed up after 150+km drive:
https://www.reddit.com/r/ft86/commen...engine_13_brz/
Cold start:
https://www.reddit.com/user/Outlandi...e_i_think_but/
When it's cold it sounds normal to me, but strange noises when warmed up.
BrzDom is offline   Reply With Quote
Old 12-21-2022, 08:11 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Noise change/go away when you put in the clutch?
Old 12-21-2022, 08:20 PM   #3
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Bonjour confrere du quebec!
The loud click clacking is normal, loud injection pump, loud direct injectors, lots of chains scootin' aboot in that big resonant timing cover, it clatters like an old kubota, an early VW EA888., or maybe even a shitpile of a BMW N20
However, there is an underlying repetitive "tsak tsak tsak tsak" which isn't part of the normal clackity clack clack of the injection system.
Mine is a manual so I can't relate, but the same noise can be heard here
Which apparently was the vacuum pump.
Old 12-22-2022, 12:19 AM   #4
Ultramaroon
not playing cards
Ultramaroon's Avatar
Yeah, vacuum pump when it has already pulled all the air it can from the brake booster. Pump the brakes rapidly and I bet the sound changes if it doesn't disappear completely.
Knocking/rattling noise when engine is warmed up??? BrzDom BRZ First-Gen (2012+) — General Topics 0 12-21-2022 06:09 PM
Rattling noise under the hood while engine is off SkinnyG Issues | Warranty | Recalls / TSB 2 01-19-2020 02:29 PM
Engine rattling noise while idling skogs Engine, Exhaust, Transmission 11 05-27-2017 01:35 PM
Rattling Engine Noise (Video with sound) mystic Southern California 21 12-28-2013 04:11 AM
Rattling noise under the hood during engine braking at low RPM Sigh-on-Rice Engine, Exhaust, Transmission 60 07-28-2013 07:48 AM
