Old 12-10-2022, 12:30 PM   #1
REVZILLA
Drives: 2013 brz
FB25 shortblock FA20 heads
Has anyone ever successfully installed a FB25 short block on fa20 heads?
Saw some discussion where the starter needs to be moved to other side transmission, fa 20 piston domes have a (bigger?) dish in them for direct injection, and possibly the combustion chamber on the head possibly needed milled.
https://www.ft86club.com/forums/show...t=45926&page=4
Looks to me like the transmission could possibly be milled out to have a left side starter without an adapter plate, and one only one bolt appears it would need left out of bellhousing. But unsure of other issues, thoughts?
REVZILLA is offline   Reply With Quote
Old 12-10-2022, 12:47 PM   #2
PulsarBeeerz
Drives: JRSC BRZ SOLD
Nah, Subi engine families don't lego like Hondas.
PulsarBeeerz is offline   Reply With Quote
The Following User Says Thank You to PulsarBeeerz For This Useful Post:
NoHaveMSG (12-10-2022)
Old 12-10-2022, 12:58 PM   #3
REVZILLA
Drives: 2013 brz
Not sure if accurate but I think Jet86 (post#70) on this thread said the heads would bolt on the block
https://www.ft86club.com/forums/show...?t=2158&page=5
Just wanting to know what the exact issue with it was- if it was just not worth the trouble or not possible
Old 12-10-2022, 04:23 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Not to mention thinner and smaller in diameter rod journals. No thanks.
https://www.ft86club.com/forums/show...3&postcount=66
Old 12-11-2022, 04:02 PM   #5
Ultramaroon
not playing cards
Ultramaroon's Avatar
Is there evidence that this change makes it less robust? I see a stiffer crankshaft swinging less mass at the rod ends. The smaller diameter also results in lower speed between bearing and journal but that probably wasn't the main goal. I'm sure the decision to give up some bearing surface for a stiffer crank involved considerable R&D.
Old 12-12-2022, 11:34 AM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
No, but you know my monkey brain just looks at it and goes "smaller bad."
I know it was discussed in that dudes NA build thread but I don't remember the outcome. I think he went with the FA20 crank and a custom rod/piston. If I get a chance I should reread the thread even though it is like 49 pages and 1/3 of it not even involving the build.
https://www.ft86club.com/forums/showthread.php?t=63901
The Following User Says Thank You to NoHaveMSG For This Useful Post:
Ultramaroon (12-12-2022)
Old 12-12-2022, 11:52 AM   #7
Ultramaroon
not playing cards
Oh, I hear you. I'm sure there was quite a bit of hand-wringing during the whole development cycle. Maybe they trimmed out some capacity for boosting. We'll see as they start popping down the road.
Old 12-15-2022, 03:05 PM   #8
D K
Stig's dark passenger
Why???
D K is offline   Reply With Quote
Old 12-15-2022, 03:08 PM   #9
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Originally Posted by D K View Post
Why???
FA20 heads from our engine are ported nicely from factory, I imagine that is the angle here
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
Old 12-15-2022, 03:28 PM   #10
Ultramaroon
not playing cards
-5 missed gif
The Following 4 Users Say Thank You to Ultramaroon For This Useful Post:
DarkPira7e (12-15-2022), NoHaveMSG (12-15-2022), soundman98 (12-16-2022), x808drifter (12-16-2022)
Old 12-15-2022, 04:40 PM   #11
D K
never mind about converting from belt to chain
Seriously, why not swap instead??
Old 12-15-2022, 06:33 PM   #12
Ultramaroon
not playing cards
If doable, I might consider it over back-converting all the sensors. Isn't that a thing too?
edit: Wait, no. I'm dumb. Already have to do that. Actually, I can't think of a good reason.
Old 12-15-2022, 06:38 PM   #13
Ultramaroon
not playing cards
Are they not for the FB?
Old 12-15-2022, 06:39 PM   #14
DarkPira7e
DarkPira7e's Avatar
I haven't seen an FB. But the FA20DIT heads are far less ported than ours so I can only assume ours were quite generous compared to their normal offering
The Following User Says Thank You to DarkPira7e For This Useful Post:
Ultramaroon (12-15-2022)
Early proposal: FA20 with a FB25 shortblock, .5l more displacement anyone? Kostamojen Engine, Exhaust, Transmission 90 03-20-2022 06:05 PM
FB25 VS FA20 Baramzisyan Engine, Exhaust, Transmission 29 10-05-2018 09:50 AM
FBM Stage 1 FA20 Shortblock FullBlown Engine, Exhaust, Bolt-Ons 2 12-21-2014 01:54 PM
Fa20 with Fb25 block. jet86 Engine, Exhaust, Transmission 49 04-23-2014 06:21 PM
FA20 Shortblock Ishii Motors Engine, Exhaust, Transmission 16 08-04-2012 09:28 AM
