Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 12-06-2022, 09:37 AM   #1
BioRebel
Drives: Mini Cooper S
Removable fender vent covers?
Does anyone know if someone makes removable covers for the front wheel well to cover up the fender vents?
I appreciate the extra cooling, but I'm not building up enough heat daily driving to justify the amount of stuff thats getting sprayed over my door.
Ideally it would be something easy to remove/replace so you can take it off for track days. Maybe something that just covers up the vent in the wheel well? Like, a simple piece of plastic would reduce MOST of the spray.
BioRebel is offline   Reply With Quote
Old 12-06-2022, 10:24 AM   #2
LRNAD90
Drives: X5 35d, D90, CX-5 Turbo
I believe the fender vents are designed to reduce drag at speed by allowing the turbulent airflow created by the wheels/tires to re-integrate more smoothly with the overall airflow around the car. I don't think it has anything to do with cooling, but I could be wrong..
LRNAD90 is offline   Reply With Quote
The Following 3 Users Say Thank You to LRNAD90 For This Useful Post:
BioRebel (12-07-2022), DocWalt (12-06-2022), timurrrr (12-09-2022)
Old 12-06-2022, 10:56 AM   #3
OkieSnuffBox
Drives: '23 BRZ Limited
This is correct.
OP, the easy solution would be to be to cut some ABS plastic to fit, stick it on the inside of the fender with some 3M tape and call it good. I doubt anyone makes anything like this.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
Old 12-06-2022, 01:08 PM   #4
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Some black duct tape right over the holes!
Dzmitry is offline   Reply With Quote
The Following 3 Users Say Thank You to Dzmitry For This Useful Post:
BioRebel (12-07-2022), soundman98 (12-06-2022), timurrrr (12-09-2022)
Old 12-06-2022, 01:27 PM   #5
OkieSnuffBox
You're right, that's even easier!
Old 12-07-2022, 08:59 AM   #6
BioRebel
I guess duct tape could work, and since it would be inside the wheel well nobody would ever see the adhesive residue.
Thanks for the info everyone.
The Following User Says Thank You to BioRebel For This Useful Post:
Dzmitry (12-07-2022)
Old 12-07-2022, 09:06 AM   #7
Dzmitry
Dzmitry's Avatar
Yeah, in the mean time, it's definitely a custom job, no matter what you try to do. So keep it simple for now, and if better solutions come up in the near future, you can always give them a shot. The residue will be a minor pain to remove, but at least it's just on plastic.
But as Okie mentioned, if you want to do a cleaner job, you could play around with shoving something in the holes to clog them up. Or maybe even attempt placing the duct tape on the inside somehow. The fender vents do come off fairly easily from what I saw in a video if you want a better look at them.
WTB/WTT: fender garnish (side vent covers) Jav Want-To-Buy Requests 3 06-24-2015 07:11 PM
WTT: my Raven frs fender vent for BRZ fender vent VakaGT Exterior Parts (Aero, Lighting, Etc.) 2 11-13-2014 02:56 AM
WTT FR-S fender vent for BRZ fender vent (white) Anthony Exterior Parts (Aero, Lighting, Etc.) 8 12-02-2013 07:52 PM
WTT: My Asphalt fender vent covers for your DGM BRZ fender vent covers SkAsphalt Canada Classifieds 0 10-07-2013 01:25 PM
TRADE: FT86 Fender Vent for BRZ Fender Vent xia Exterior Parts (Aero, Lighting, Etc.) 0 10-04-2013 09:56 PM
