Old 11-28-2022, 12:00 PM   #1
scottryan
Financial Distress
scottryan's Avatar
Drives: 2017 GT86 325WHP
Blitz Big Caliper Kit II
Does anyone here have experience with the Blitz BBK II 6pot Front 4pot Rear set? I'm considering this over brembos because I have an opportunity to get the kit at a fair price and had a question about rotor replacement.
The kit uses a 2pc rotor, would you have to order a new rotor from the manufacturer when you wish to replace, or is the 2pc compatible with ones found domestically in North America and bolts right on to the center piece?
Also was wondering if anyone does run them, what the clearance is like for their wheels that they run and if they could share their wheel specs.
Thank you
scottryan is offline   Reply With Quote
Old 11-30-2022, 09:23 AM   #2
Racecomp Engineering
I would suggest contacting the manufacturer for information on things like replacement parts (cost/availability) AND to see how easy it is to get a response from them. Might be great, might be lacking...but it's one of those things where you can end up with an expensive paper weight.
- Andrew
Old 12-04-2022, 04:48 AM   #3
churchx
churchx's Avatar
Drives: 2014 GT86
Also on some "fair price" as primary pro on suspension or BBK products, i often expect them ensuring just "bigger/shinier/blingier" and mechanical fit on car, less extensive R&D & testing how it really affects handling.
For street i suggest to not waste money on BBK. No gains but waste of money.
For track .. at beginning i advise to try on stock brakes (with brake pads intended for track & better brake fluid), and only after initial phase consider BBK (but i'd probably prefer something from known manufacturers, like Essex APR kits or Willwood's, or kits developed/sold by known tuning shops eg. CSG).
Old 12-04-2022, 09:52 AM   #4
fryfun
Drives: 2014 Subaru BRZ DGM Limited
Blitz is a known manufacturer/tuner like the ones you listed . The main problem is their product support may not be as convenient in the NA cuz they are based in Japan.
fryfun is offline   Reply With Quote
Old 12-27-2022, 05:34 PM   #5
themadscientist
Hotlink Terrorist
themadscientist's Avatar
Drives: 2015 WRB BRZ Spec S
As a long term owner of the Wilwood BBK kit I'd agree with him. I street drive in a spirted fashion (read between the lines) and with some slotted replacement rotors and sports pads I never ran out of brake. In the most agressive and urgent stopping situations it felt like I was at about 90% of the capacity and I drive like a real A-hole. I think with a slightly hotter pad and stainless mesh hoses the car would have been perfect. My car is the middle tier Spec S with the brakes in between base and the factory Brembos. The base model brakes would likely come up short.
The BBK is great, (the Wilwood at least, never tried the Blitz) but those serious braking events now feel like 50% capacity. The balance was unaffected; everything scaled up nice and even, but unless you are hard tracking the car every weekend it's overkill. Nothing wrong with overkill, it's my MO, but don't go big because you think you NEED to; you don't.
+1 for sticking to established brands. Blitz is likely farming out production of these parts and while they may be quality (I don't know if they are) down the road when you need replacement parts you may be out of luck.
bbk, big brake kit, blitz, brake, japan
Brembo BM-4 caliper Randoman5 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 81 07-18-2024 09:45 PM
Cts-V caliper question Uncle86 BRZ First-Gen (2012+) — General Topics 1 05-23-2022 04:09 PM
WTB OEM caliper brackets troek Brakes, Suspension, Chassis 0 01-27-2014 10:32 PM
MGP caliper Covers USMC -FRS Cosmetic Modification (Interior/Exterior/Lighting) 9 02-06-2013 10:15 PM
Would you get these?...Caliper covers mckobus Cosmetic Modification (Interior/Exterior/Lighting) 35 01-28-2013 09:27 PM
