Drives: 2023 BRZ, 1990 Miata
2023 BRZ fitment - APEX ARC-8
Hey all,
I have a 2023 BRZ that is bone stock and is just my daily driver. I'm loving APEX's ARC-8 and want to put them on my car. I'm assuming the 17x9 +42 fitment is the best? I want to do zero modification in terms of spacers, fender, camber, ride height, etc. - basically I want a bolt on fit with no issues - is this possible with those wheels and 235/40/17 Advan Fleva V701? Thanks! |
Rust bucket enthusiast
The wheels were made to be near perfect fitment at this size. It'll be great. On stock suspension, they fit my car well but my 245/45 tires were close to stock spring perches, 235/40 should be great
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block Last edited by DarkPira7e; 11-27-2022 at 02:17 PM. |
Thanks for your input - do you know if it's any different on the 2nd gens? I've heard the fitment choices are worse and I don't want to order them based on info from the first gens.
#4 | |
Very good point. This is from the Apex website for the 17x9 ARC-8
Source - https://support.apexraceparts.com/hc...-Fitment-Guide
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block Last edited by DarkPira7e; 11-27-2022 at 02:34 PM. |
Drives: '23 GR86 Neptune PMT
On stock suspension, the rear clearance will be fine with a 235 section tire. The only issue I’d worry about is the front clearance on the spring perch, however if you are not adding camber via camber bolts then it shouldn’t be a problem.
I run ARC-8s on my GR86 with no spacers, however I do have coilovers and some other suspension modifications. |
No issues with those wheels and 235/40/17 tires. You’ll have about 9 mm clearance to the front sprint perch on stock camber on a tire like the gt radial champiro sx2. A little bit of poke.
2022 BRZ Build 2013 FR-S Build |
| 2023 G87 BMW M2 | Kiske | Other Vehicles & General Automotive Discussions | 65 | 10-18-2022 05:19 PM |
| 2023 Production | autosenses | BRZ Second-Gen (2022+) — General Topics | 28 | 05-19-2022 03:52 PM |
| ► APEX | Subaru BRZ tS Track Car Featuring APEX 17" ARC-8 Wheels | APEX Race Parts | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 9 | 02-02-2021 12:59 AM |
| ► APEX | Tire Slayer LS2 Powered FRS - Featuring APEX ARC-8 Wheels | APEX Race Parts | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 12-02-2019 01:03 AM |
| ► APEX | Tire Slayer LS2 Powered FRS - Featuring APEX ARC-8 Wheels | APEX Race Parts | Tracking / Autocross / HPDE / Drifting | 2 | 11-30-2019 12:17 AM |
