Old 11-19-2022, 01:36 PM   #1
gpvecchi
gpvecchi's Avatar
Bucket seat or not?
I don't feel good in stock seat, my shoulders are wider than the support and I slip outside in hard corners.
I tried many Recaro and Bride seats in Japan, and the best one to my body was the Pole Position.
As I daily drive my car, how much difficult is to enter and exit the car with a bucket seat compared to another sport seat, like the Sportster CS?
gpvecchi is offline   Reply With Quote
Old 11-19-2022, 02:21 PM   #2
RedReplicant
Drives: None
This is going to heavily vary seat to seat.
It is worth noting that a lot of bucket seats do not work properly with the stock seatbelt - some people run the lap belt over the sides, some people need seat belt extenders that sit inside of the bucket area and take up a lot of hip room (and are uncomfortable), a lot of the times the lap belt no longer runs over the correct area of your hip, some organizations require all or nothing in terms of bucket means 5/6pt plus roll bar, etc.
Bucket seats are the first step down the path of starting to hate your car on the street, at least in my experience.
RedReplicant is offline   Reply With Quote
Old 11-20-2022, 01:53 AM   #3
Falkon240
Falkon240's Avatar
Drives: 2013 FRS
I have two bucket seats in my FRS.
FWIW I'm about 210 34 waist 5'11
The driver seat is a Buddy Club P1 "regular" size with a Bride FG rail.
Pros: I like how it holds me, sits low and looks great.
Cons:
  • The seat belt is a minor annoyance due to how low the seat is.
  • If I don't take the steering wheel off it can be pretty cumbersome to squeeze in and out.
  • Getting in and out is ... ok. The door stays often almost causing the door to close on my hand as I get in and out of the car.
I recently put the passenger reclinable seat in the reclinable is on a Bride FO rail. It sits much higher and doesn't move far forward to gain access to the rear seat because the top of the seat hits the headliner near the visor area.
It doesn't move far back because of the thickness of the upper seat part hitting the back seat.
This isn't my only car so daily drivability isn't as important as it once was when I was younger.
IG
2013 Scion FR-S
2022 Chevrolet Colorado ZR2 Bison
1998 Nissan 240SX KA24DET
Falkon240 is offline   Reply With Quote
Old 11-20-2022, 03:24 AM   #4
gpvecchi
gpvecchi's Avatar
The Recaro Pole Position ABE has specific holes for passing the stock seatbelt.
I'm just debated on how much difficult is to enter and exit the car with that seat and how much it is with another reclining seat.
Getting a removable steering wheel is not an option, as it's illegal in my country.
Old 11-20-2022, 08:29 AM   #5
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
I was under the impresioon the car only came with bucket seats up front.
Is the twin also a motorcycle to you?
Old 11-20-2022, 10:00 AM   #6
soundman98
ProCrastinationConsultant
soundman98's Avatar
lol.
so the words matter, but not the spelling?
Old 11-20-2022, 12:51 PM   #7
norcalpb
norcalpb's Avatar
I’ve sat in both the PP and Sportster CS, and while it’s not hard to climb into the PP, I could see it getting old after a while for DD use. I find that when the seat of a vehicle is harder to enter, the driver of the vehicle will more likely than not choose another vehicle to drive around town (if one is available).
So I vote sportster CS for sure DD use. There is also the sportster gt:
Old 11-21-2022, 01:01 AM   #8
gpvecchi
gpvecchi's Avatar
Thanks for your answer. I don't have another car to choose...��
What do you mean by getting old? Wear out?
Old 11-21-2022, 07:23 AM   #9
x808drifter
LMGTFY
lol.
I honestly thought I fixed that. Welp.
Old 11-21-2022, 03:36 PM   #10
norcalpb
norcalpb's Avatar
In my experience it just becomes cumbersome getting in and out of a true bucket seat when you are driving it on the street. Instead of gently sliding into the seat, you'll find yourself hopping over the bolsters and lowering yourself into the seat with your triceps. It's a cool feeling for sure but may subconsciously make you not want to drive the car as much. You've obviously had your car for a damn long time, so I'd hate to see you "ruin" the connection you have with your car by "going too far" with it. After all, you just want room for your shoulders.
Reclinable Recaro or Bride for the street IMHO.
Old 11-21-2022, 04:37 PM   #11
gpvecchi
gpvecchi's Avatar
I can't fit any Bride, they are too tight for me. Pole Position is almost perfect, a little tight at the shoulders, but this is the expected behaviour. Sportster is too wide, but not bad in alcantara version. The side of the cushion are really high, much more than the Pole Position, so I don't know if it's so comfy to sit on it...
Old 11-21-2022, 08:15 PM   #12
soundman98
soundman98's Avatar
you left the door wide open, i couldn't leave it!
Old 11-22-2022, 02:45 PM   #13
Racecomp Engineering
The Pole Positon ABE is probably the only fixed back I'd consider for street driving, but I'd still much prefer a Recaro Sportser or SR7 (JDM market seat).
Even if I don't mind getting in or out of them, passengers generally hate it.
I'm 37.
- Andrew
Old 11-22-2022, 03:57 PM   #14
gpvecchi
gpvecchi's Avatar
SR-7 is very beautiful and really, really comfortable! The lateral support is not so different from stock anyway... Sportster is a little more sporty (more stiff and more shoulder support)
FS: Sparco Evo 2 Bucket Seat sebastiansim Interior Parts (Incl. Lighting) 1 07-31-2016 09:20 PM
FS: Sparco Evo 2 Bucket Seat sebastiansim NY / NJ / CT / PA 1 07-31-2016 09:11 PM
Bucket seat store locations? CyberFormula Cosmetic Modification (Interior/Exterior/Lighting) 0 02-21-2013 09:16 PM
