Old 11-02-2022, 10:21 AM   #1
Marckussb
Drives: 2016 frs boosty boi
No Revlimiter? Help
I recently purchased a 2016 frs with the JDL Turbo kit.
The previous owner told me the car was dyno tuned (have proof of the chart) with Ecutek.
He included the Ecutek (looks like a standard OFT, not Ecutek)
My issue is there doesn't seem to be a revlimiter in place. I've seen the car rev to 8,000rpms when traction breaks loose and obviously I want to put an end to that. I do plan to slide the car so watching the revs in that range isn't always the easiest and would like a fallback.
Can I add a revlimiter with the OFT WITHOUT wiping and software or tuning that was done on the dyno?
I'm obviously new to this and want to do it right.
Marckussb is offline   Reply With Quote
Old 11-02-2022, 11:16 AM   #2
tomm.brz
Drives: brz 2017 hksv2
No, it needs to be rewritten, so either you find the tuner that did the tune ( and hopefully still has your tune somewhere) or you need to retune from scratch
Old 11-03-2022, 07:34 AM   #3
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Woulda just walked away right there.
Pics of the tuning solution just to be clear would help.
EcuTEK
OFT
Old 11-03-2022, 07:59 AM   #4
AussieBRZ
AussieBRZ's Avatar
Drives: WRB BRZ
If it's ecutek tuned you won't be able to read tune from ECU.
Your only chance would be get copy of tune from the original tuner, or get them to lower the rev limiter
If it's oft tuned you can read tune out with another tool like less or tactrix. But tune may also be on oft
AussieBRZ is offline   Reply With Quote
Old 11-03-2022, 08:23 PM   #5
Marckussb
EcuTEK
OFT
100% OFT
Old 11-03-2022, 08:57 PM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
100% OFT
I'd get ahold of the seller and ask who tuned it as mentioned earlier, and then get ahold of the tuner. He may have given you an OFT but I would be surprised if it was tuned for the turbo with it.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
x808drifter (11-04-2022)
Old 11-04-2022, 07:07 AM   #7
x808drifter
LMGTFY
I can read and tune mine fine....
But I do also have RaceRom unlocked.
Old 11-04-2022, 07:25 AM   #8
tomm.brz
Only master tuners with master licence can read a tune out of an ecutek Tuned car, i also have racerom license but can t do it as i m not a Master tuner and neithet are you..
if he has oft anyway it s easier as Steve said, maybe he even has the tunes saved in his oft?
Old 11-04-2022, 07:49 AM   #9
Good to know!
Old 11-04-2022, 08:24 AM   #10
AussieBRZ
AussieBRZ's Avatar
Drives: WRB BRZ
Even tuner level ecutek you can only read out your own tunes, you cannot read out other tuners tunes.
Old 11-04-2022, 08:26 AM   #11
AussieBRZ
AussieBRZ's Avatar
Drives: WRB BRZ
With tuner level you can read tunes out with ecutek but only tunes you wrote in you won't be able to read tunes written by a different tuner
The dump or read for ecutek reads but it in encrypted format that cannot be used other than by ecutek in england
Old 11-04-2022, 09:14 AM   #12
tomm.brz
You know i have tuner lever license Stewie but i can t read my own tune out of the ecu we talked about this and showed u pics, it just doesnt work
if you mean the dump, well that s useless for us, and i just don t even have the READ ECU button in my proecu
Old 11-07-2022, 09:42 AM   #13
Marckussb
Rev limiter is set to 8k.
Got a hold of the turner but they would not provide any info related to the car.
I let it warm up and pinned it and it stopped at 8k.
It does occasionally stop at 4k as if it has launch control but this isn't repeatable consistently, which seems odd.
Old 11-07-2022, 09:45 AM   #14
tomm.brz
with cluch pedal pressed it will trigger the launch if you then floor the accel pedal
revlimiter Gauges therealstoly User/Vendor/Sponsor Reviews, Feedback, Comments 2 04-27-2023 04:03 AM
