Old 11-01-2022, 05:11 PM   #1
afishl1
Drives: Raven FRS MT
Where would you start?
Ok, so you (me=2013, 70K) have your FR-S with a bunch of different rattles from all sorts of different scenarios, instead of me trying to explain each one, I was thinking maybe I could just start upgrading/replacing some of the low hanging fruit which typically have problems anyway.
So, what would be your list of things to start changing in hopes that some issues might get resolved anyway, starting with the cheapest/easiest to fix and going from there?
afishl1 is offline   Reply With Quote
Old 11-01-2022, 05:23 PM   #2
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
First thing I would do is explain each one, find out which are normal, and which ones aren't, and prioritize.
Old 11-01-2022, 06:09 PM   #3
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
The first thing I would do is find the most obvious rattle and fix it. Then I would find the next most obvious rattle and fix it.
Nothing can seem daunting like a car that sounds like a mechanical keyboard going over bumps and around bends, but as you'll start to eliminate the easiest ones, the others will become easier in turn, because you dont have 12 simulatenous rattles going on anymore.
Old 11-01-2022, 10:23 PM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Take off your door panels, gorilla tape on the radio buttons, air impact hammer on all suspension components, take out passenger seat, remove heads from block, take out short block, remove direct injection
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
Old 11-02-2022, 06:28 AM   #5
tobin
tobin's Avatar
Drives: '13 BRZ
Have a friend drive the car so you can crawl around and push on different areas to help pinpoint where the sounds are coming from.
tobin is offline   Reply With Quote
Old 11-02-2022, 07:28 AM   #6
WNDSRFR
Drives: FR-S,GTI
Get a louder exhaust. And noisier tires. The rattles will disappear.
Old 11-02-2022, 08:14 AM   #7
It is a 10 year old car that rattled when it was new so trying to tackle it now will be a challenge. Fixing one rattle is more than likely just going to cause another.
Just be glad you don't live where it get's really cold!
Old 11-02-2022, 09:35 AM   #8
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Totaled.
Stall/No Re-start with push button start couver Scion FR-S / Toyota 86 GT86 General Forum 11 06-26-2020 10:32 PM
FS: STI engine start push start OEM plug and play sokol Interior Parts (Incl. Lighting) 5 06-13-2019 02:12 PM
Car won't start. Limited with push to start. uEih Issues | Warranty | Recalls / TSB 22 01-06-2017 11:54 AM
Pushed start.. didnt start im_topher Engine, Exhaust, Transmission 86 11-29-2015 09:57 AM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 03:44 AM
