Old 10-27-2022, 08:06 PM   #1
FRS-I
FRS-I's Avatar
Drives: 2013 10-Series FRS
Exclamation IRP SHORT THROW REVERSE ISSUE
I was wondering if I had installed this incorrectly somehow or if I'm just not used to all of the mods I just threw into my car at once, but when I put the IRP Short Throw Shifter into reverse it does not feel like it wants to sit properly and cannot figure out if the gear is making weird noises (even when fully in reverse no clutch) or if it's just welded diff, stage 3 clutch noises.
When I installed it I set the 4 bolts around assembly with washer in 1st and 6th should I re-do it in Reverse since it's further left? It still didn't feel quite right because it was loose without being bolted down fully.
Could there be something stopping/blocking the reverse?
I'll post pictures/a video of the noise ASAP. Thank you for any help!
Taking time to destroy before I rebuild.
FRS-I is offline   Reply With Quote
Old 10-27-2022, 09:01 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Okay, this is a really hard to read post.
You adjust the limiting screws based on 1st(left screw) and 6th(right screw). Pressing down on the button pulls back the pin so that the limiting screws don't do anything and you can go all the way over to engage reverse. The only adjustment to the IRP besides the limiting screws is moving the base forward/backwards which isn't going to effect reverse engagement. It will just change the angle of the shifter. The only question I have in regards to your shifter is the limiting screws towards the rear of the car, or the front?
What clutch is in your car specifically? I would lean in that direction. Could just be a pedal adjustment.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
villainous_frx (10-27-2022)
irp, issues, shifter
2023 BRZ with sti short throw shifter doesnt feel short! karFreak BRZ Second-Gen (2022+) — General Topics 11 09-22-2022 07:26 PM
FS: STI JDM short throw shifter steel86gt Southern California 7 12-11-2018 10:52 PM
New STI Short throw in 2015? tuckn'roll Engine, Exhaust, Transmission 2 05-05-2018 02:51 PM
wtb short throw shifter SciOnDrifTtSlIdeR Canada Classifieds 7 02-11-2014 08:24 PM
TWM Short Throw Shifter UltraFRS Engine, Exhaust, Transmission 12 01-28-2014 01:56 PM
