Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 10-03-2022, 09:52 AM   #1
mr.whiskers
Drives: '22 BRZ
Dumb question. Shifting into second gear
I don't have much experience with driving manual, but I want to keep my car healthy for as long as possible.
After having the car for almost a year, I am still a bit hesitant about shifting into second or if I am doing it correctly so I wanted to see what other people do.
Basically my issue is shifting into second from first feels like there is some extra resistance there compared to other gears. It is especially more noticeable while the car is cold. It feels like I am forcing it in. Other gears after that are fine. Also I noticed after the car warms up this feeling of forcing the second gear in is not as bad anymore.
What I have been trying lately is from first gear I would shift into neutral, and then go second and this actually feels much better compared to directly moving the shifter from top to bottom in a straight line.
How do other people shift and what is the correct way?
mr.whiskers is offline   Reply With Quote
Old 10-03-2022, 10:37 AM   #2
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
Some gearbox oils make it hard to shift into 2nd gear until it`s warmed up.
gen3v8 is offline   Reply With Quote
Old 10-03-2022, 02:09 PM   #3
Decep
Drives: 2013 FR-S Series 10
Usually helps if before you take off, work the stick (pause) through all the gears a few times at a standstill. Also it sounds counter intuitive but when it's cold its better to make the shift with all one motion, try not to pause too long in between 1st and 2nd.
It'll get better as you pile the miles on.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Old 10-03-2022, 07:47 PM   #4
soundman98
ProCrastinationConsultant
soundman98's Avatar
you're working against the syncro's. try shifting into 2nd when the rpm's are closer to where they would be for the gear.
Old 10-04-2022, 06:27 AM   #5
CedN
CedN's Avatar
Drives: 2013 GT86 fully standard
Probably then only thing i dislike with my 86, especially since i live in a cold country. I sometimes just go to from 1st to 3rd instead on upshifts, double clutch matched shifts can help, but not always. I also noticed 2nd goes in easier at upshifts if shifted at really low rpms, instead of reving up on 1st first.
2013 GT86, fully standard daily and occasional track day car
CedN is offline   Reply With Quote
Old 10-04-2022, 08:15 AM   #6
fredzy
Mebmer
fredzy's Avatar
Drives: Sienna, GR86, TourX
Yeah this. As OP says, seems better when shifting to neutral, (I guess) pausing, then to second. That's because engine speed (*edit* and transmission speed, once in neutral) had more time to drop down to the right RPM for a smooth entry.
My 350Z had bad syncros. I tried a few different gear oils and ended up putting the OEM Nissan stuff back in.
My process for 1st to second for the first couple cold shifts was to pop from first to neutral, wiggle the stick side to side (as a way of making a repeatable delay) then it would fall into 2nd easy as the revs would be matched. And as CedN says the lower the RPM the better especially as this technique would mean engine revs would be a smidge low once actually releasing the clutch. Double clutching seemed very hit or miss for 1 to 2, but was useful from 2 to 3 where the trans had maybe worse problems.
fredzy is offline   Reply With Quote
Old 10-04-2022, 09:44 AM   #7
StraightOuttaCanadaEh
Wes
This is what I did. Changed the tranny fluid, installed MTEC shifter springs and perrin/whiteline shifter bushing combo (they come as a package). Night and day difference, really crisps up the shifts, no more issues.
Instagram: @gt86ws
Old 10-04-2022, 12:24 PM   #8
Decep
the shifter bushing and transmission mount bushing DO help a surprising amount when its cold.
RCE SS-1 Coilovers
Corsa Catback
Old 10-04-2022, 04:08 PM   #9
mr.whiskers
Drives: '22 BRZ
Hm that sounds about right, so basically I am shifting too fast and not letting the revs fall enough
Old 10-04-2022, 07:40 PM   #10
Interceptor777
Interceptor777's Avatar
Drives: 2022 BRZ, 1999 "touge-spec" Miata
Yeah 1st to 2nd is the trickiest to get right perfectly, and cold gearbox exaggerates that. It also doesn't help that 1st has huge rev hang.
Sent from my SM-S908U1 using Tapatalk
Interceptor777 is offline   Reply With Quote
Old 10-05-2022, 11:09 AM   #11
CedN
CedN's Avatar
Which bushings did you change to more specific?
Old 10-05-2022, 01:00 PM   #12
Wes
it's this package
https://www.ft86motorsports.com/perr...-fr-s-brz.html
I now also have subframe inserts from Whiteline, the STI trans mount, Perrin engine mounts, I used to have whiteline outrigger diff bushing inserts as well. Every single drivetrain mod added NVH but improved shifting.
Instagram: @gt86ws
Old 10-05-2022, 01:38 PM   #13
Decep
That combo helps shift feel so much, but be warned it can make your car sound like a big rig at times with all the gear whine. i hated it at first, but eventually found it endearing.
RCE SS-1 Coilovers
Corsa Catback
Old 10-06-2022, 04:20 PM   #14
mr.whiskers
Drives: '22 BRZ
Do you think double clutching into second while its cold is a good idea? I tried it today and the shift was super smooth
A dumb question ckilburn_ Electronics | Audio | NAV | Infotainment 9 06-05-2018 08:45 AM
Dumb Question 22R Software Tuning 3 10-30-2017 05:19 PM
Turn Signal Relay Question (Dumb Question) Chimera Cosmetic Modification (Interior/Exterior/Lighting) 3 06-23-2017 01:58 AM
might be a dumb question TooChang Scion FR-S / Toyota 86 GT86 General Forum 1 08-05-2014 10:10 PM
Dumb question ExWhyZer0 Electronics | Audio | NAV | Infotainment 2 01-25-2013 06:44 PM
