Drives: 2017 GT86
GT86 2017 Daytime Running Light (DRL)
I have just sourced a 2017 GT86 from Japan and read about DRL being illegal there 🤷*♂️
I took a look at the engine compartment fuse box and the DRL relay is missing so is the socket. Wondering if anyone able to hook back up the oem headlight's drl to the car's drl system. |
DRL are not illegal in Japan, simply they are not mandatory.
The DRL function is hard coded into BCM software, so you need to change it to an EU model, or you can buy a DRL kit from Japan. There are various types, the cheapest is a small harness that feeds the DRL sourcing the power from the headlights height motor. If you need it, I have a 2019 BCM module for sale, but I'm located in Italy... |
#3 | |
Drives: 2017 GT86
I think that's the behaviour of EU cars. I'm sure of the behaviours because I replaced my EU BCM with the JDM one to enable the theft alarm, and the DRL were gone.
The cheapest way is the harness you can find on Rakuten or Yahoo Auction. |
| Daytime Running Light delete TSB! | Memphis | Issues | Warranty | Recalls / TSB | 256 | 07-22-2017 10:55 PM |
| Daytime Running Light options that retain high beams? | ELLSSUU | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 10-09-2016 09:29 PM |
| SCION FR-S LED DRL Daytime running light fog lamp cover | GT/86 | Cosmetic Modification (Interior/Exterior/Lighting) | 12 | 07-20-2014 08:08 PM |
| Daytime Running Light Issue | AnthonyArcaro | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 07-01-2014 07:46 PM |
| Daytime Running Light/ Crystal Vision Ultra | Memphis | Cosmetic Modification (Interior/Exterior/Lighting) | 14 | 02-08-2014 06:52 PM |
