Tracking / Autocross / HPDE / Drifting What these cars were built for! |
09-30-2022, 11:36 AM | #1 |
Drives: Toyota GT86
Too much brake pad ?
Is something like the Project Mu 999 too much brake pad for a stock car running pilot sport 4 tires ?
For track usage only. Will be running OEM pads on the street. Not sure if it matters but the format of the track day is open pit lane so no run groups and I will have two drivers in the car.
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
09-30-2022, 12:23 PM | #2 |
Drives: 2013 FR-S, 2017 BRZ
As long as the brakes get up to their proper operating temp range and are balanced front/rear, then IMO you can never have 'too much pad' unless you have a hard time modulating the brakes.
Project Mu website says 200-800C rotor temperature range, so I'd expect you can get there and stay in it once the car is warmed up. I wouldn't use these in a low grip situation or rain because they'd be very aggressive and prone to lockup/ABS, as well as too low operating temp. There are pads out there which would be better suited to the situation, but these will work for you since that was the original question. |
The Following User Says Thank You to Matt93SE For This Useful Post: | autoracer86 (09-30-2022) |
09-30-2022, 02:21 PM | #3 |
Drives: Toyota GT86
Thanks for the info Matt. After a bit of back and forth on my end I have ended up going with the CL pads in the RC6 compound from a local race shop
09-30-2022, 03:10 PM | #4 |
Drives: Subaru BRZ / Toyota 86 Experts
The CL sintered compounds do have excellent control compared to the 999, however, you'll want to be mindful of keeping the brake temps in check. Both CL and 999 do run incredibly hot so monitor your caliper seals and such.
09-30-2022, 04:42 PM | #5 | |
Drives: Toyota GT86
Thanks for the information. I guess a cool down lap or two is in my future lol
The Following User Says Thank You to autoracer86 For This Useful Post: | CounterSpace Garage (09-30-2022) |
09-30-2022, 04:55 PM | #6 |
The Following User Says Thank You to CounterSpace Garage For This Useful Post: | Matt93SE (09-30-2022) |
Similar Threads | ||||
FS: OEM Brake Rotors + Brake Lines + Clutch Line + Steering Rack Bushings | fc3s_johnny | Brakes, Suspension, Chassis | 11 | 10-05-2020 10:26 AM |
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! | eauto | Brakes, Suspension, Chassis | 255 | 10-15-2014 01:45 PM |
FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot | CamryDS | Interior Parts (Incl. Lighting) | 0 | 06-24-2013 11:26 PM |
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS | Redline360 | Brakes, Suspension, Chassis | 12 | 01-05-2013 10:20 PM |
