Old 09-27-2022, 08:40 PM   #1
Hikari1
Hikari1's Avatar
Drives: 2016 BRZ Hikari
S/C BRZ running lean, stalling, surging
Hey everyone, hoping I can get some help here.
Been running an Edelbrock supercharger for about 2 years, regular oil changes, build list here:
Edelbrock S/C
Updated Bypass Valve
Tomei Header & Overpipe
HKS dual res Front Pipe
Full Blown Motorsports Oil Cooler
Tuned by Delicious
OEM fuel pump and injectors
OEM spark plugs and coil packs
85,000km
Car handled the track day fine, except for when the belt slipped and sheared off a rib. Swapped to a spare and drove 30min to cottage fine. 2 days later went to drive home and about 15min into the drive I noticed RPMs drop while cruising at about 80km/h in 5th gear. I could hear the belt chirp everytime the AC compressor kick on so I assumed the belt was stretched as it was an old I kept as spare. Seemed to run fine after turning off the AC for the remaining hour home.
Swapped to a brand new belt, car drove fine for about 30min to a meet, when trying to leave the meet the car would start up but then stall when going to idle. I thought it might be out of gas as it was very low and I planned to get more next to the meet before I left. I filled it with 20 litres and it still had an issue stalling at idle on startup. I was able to get it to idle by applying throttle at startup for a couple seconds and it would idle fine after that. Drove it home and AFRs seemed to be okay, thought it was the fuel being low.
Couple days later I drove 30min, car seemed completely fine on highway and city streets, when suddenly, going 60kmh the car started surging wildly, RPMs bouncing up and down and AFRs all over the place. I put the clutch in and the engine stalled immediately. When trying to restart it kept stalling on idle. I managed to get it to keep running by giving gas, it chugged a bit at low speed at first but after a minute it drove 5min to my dad’s place fine.
I've been trying to diagnose the problem but I'm at a loss. The car on cold start will start up although will be running rich, about 12.5-13... I let it idle for about 20min to warm up and was still showing the same on the wideband. I slowly brought the revs up to see if there was any change and the wideband spiked to 17.5 and higher so I let it come back to idle and it remained running lean. Every attempt at starting the car following it being warm resulted in the engine stalling on startup, even when attempting to add throttle.
I can hear the fuel pump priming when I turn the car on, fuel pressures look fine as well. I replaced the PCV valve as there was a slight leak on it, no change. I've swapped with a spare MAF and the issue is still the same. I checked the bypass valve on the Edelbrock, it doesn't stick at all, holds vacuum, and holds pressure. I pulled the passenger spark plugs as they were original with 85,000km on them, 20,000km of that with boost and 5 track days. The tips were very white so I'm replacing with new ones regardless.
I did some data logging for Bill @ Delicious of its behaviour, but I’m at a lost for what it could be at this point.
Logs are at this link if you want to look:
Log 1
Log 2
Log 3
2016 BRZ Hikari Edition
@BRZHikari1
Build Thread:
http://www.ft86club.com/forums/showthread.php?t=107326
Hikari1 is offline   Reply With Quote
Old 09-28-2022, 03:33 AM   #2
tomm.brz
Drives: brz 2017 hksv2
Sorry, logs need to be loaded in datazap.me and then linked here
Old 09-28-2022, 09:13 AM   #3
Hikari1
Hikari1's Avatar
Oops, fixed!
@BRZHikari1
Build Thread:
Old 10-05-2022, 10:23 AM   #4
Hikari1
Hikari1's Avatar
Fixed the issue, I replaced the sparkplugs with new OEM ones and also cleaned the MAP sensor. The car has been driving fine since!
@BRZHikari1
Build Thread:
The Following 2 Users Say Thank You to Hikari1 For This Useful Post:
tomm.brz (10-05-2022), x808drifter (10-06-2022)
Surging/stalling when accelerating. intermittent issue scarysquash Issues | Warranty | Recalls / TSB 17 09-09-2025 11:16 AM
P0300, P0303, Rough Idle/Surging and Stalling, 2017 BRZ 6MT bone stock 96z2 Issues | Warranty | Recalls / TSB 21 11-13-2022 03:05 PM
Running Lean, Surging, Stalling after track day Hikari1 Forced Induction 2 09-19-2022 10:25 AM
pcv delete, surging idle, stalling. solidsnake11 Software Tuning 0 10-01-2020 11:01 PM
Car Running Lean MyGT86Yas Software Tuning 9 09-24-2019 07:46 PM
