Old 09-23-2022, 05:29 PM   #1
Spelot
Drives: Frs 2013
Creaking pop noise on acceleration intermittent
Please help me diagnose this sound. I thought it was a loose exhaust hanger by transmission crossover or torque rod by starter. Mechanic could not diagnose it. Sounds like it’s coming from intake. 80k miles, stock tune, 91 octane, Trd exhaust.
2014 Frs
Intermittent problem. But it’s happening more regularly. It creaks not on acceleration under load in all gears 2500-3300 rpm. and it does a quick pop in neutral when you dab the gas pedal.
Car runs amazing
Please help
Thanks
Spelot is offline   Reply With Quote
The Following User Says Thank You to Spelot For This Useful Post:
humfrz (09-24-2022)
Old 09-24-2022, 12:26 PM   #2
Sevs753
Sevs753's Avatar
Drives: BRZ, Canyon
My first thought is the direct injector seals. I don't remember exactly when the stock tunes had the fix but thats what your video and description sound like to me.
Sevs753 is offline   Reply With Quote
Old 09-24-2022, 07:43 PM   #3
humfrz
Hello Spelot and welcome to ...... The Forum -
Does your car make that sound when it's stationary?
If it only does it when it's moving, it may be a lose heat shield or under panel.
Old 09-25-2022, 12:04 AM   #4
Spelot
Drives: Frs 2013
Hello, Thanks for the input. It mostly makes the noise while moving and in gear. But we can can replicate the noise on the lift and accelerating in gear. It will make a quick creak or pop if its in neutral and the gas is stabbed.
humfrz (09-25-2022)
Old 09-25-2022, 12:06 AM   #5
Spelot
Drives: Frs 2013
Hello, Thanks for the input on the direct injection seals. I'll look deeper into this.
engine noise, exhaust, intermittent, valve spring
Popping, Crunching and Creaking Noise MyEvilMonkeys Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 07-22-2020 12:50 PM
Creaking noise while turning WRITEX Issues | Warranty | Recalls / TSB 20 01-26-2020 05:25 PM
Creaking noise coming from the rear alex87f Issues | Warranty | Recalls / TSB 9 10-08-2018 11:47 AM
Creaking noise from overpipe sydious Engine, Exhaust, Transmission 4 06-27-2018 02:13 AM
Acceleration Lag - Intermittent donnyk CANADA 6 07-17-2013 11:53 PM
