Old 09-22-2022, 11:21 AM   #1
GJR726WY
Drives: 2013 Subaru BRZ
2013 BRZ "slipping?" "bucking?" on highway ...
Good morning everyone. I'm having a weird issue with my BRZ and after working it on it for a few weeks and searching and searching forums and the internet, researching , reading service manual, I am at my wit's end ...
2013 Subaru BRZ 6MT DD - mechanically stock except for K&N drop in filter and IP coil-packs (plugs done as well) I bought the car with 52,000 miles have changed all fluids and had to replace clutch/flywheel from fused throw-out bearing, new battery earlier this year.
When driving down the highway at a constant speed I am getting an intermittent random bucking or shudder. It's not violent per se, like a bucking bull or anything like that. It's really hard to describe in text. It almost feels like maybe the tires skipping on very small different sized black-ice patches or something, but its of course on dry-pavement. I'm not getting any CELs, no obvious noises, no obvious deviations in engine RPM. I've cleaned MAF, air filter, changed fuel ...
I have no idea where to go from here. We recently moved from WY to AZ and I know I cannot currently get Ethanol free fuel here, which I always ran before, but that is going to be a difficult solution. Without any CELs I don't even know if it's a fueling issue, or maybe something in the drivetrain?? I am at a loss, but need this thing to commute to work and would like to get it fixed.
Does anyone have any suggestions? Or run into this issue before? I've went through a lot of forum posts and couldn't pinpoint this specific item...
GJR726WY is offline   Reply With Quote
Old 09-22-2022, 11:44 AM   #2
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Check tire pressures?
ETA: Have you tried turning all traction control off?
dragoontwo is offline   Reply With Quote
Old 09-22-2022, 12:34 PM   #3
WNDSRFR
Drives: FR-S,GTI
Wheel balance?
Old 09-22-2022, 02:42 PM   #4
GJR726WY
The tires and wheels are in good shape. This doesn't feel like anything tire related.
Old 09-22-2022, 05:06 PM   #5
radroach
Drives: car
The aftermarket coil packs might clue us in on something. If you suspect its engine related, I'd get a bluetooth OBD II reader and torque app and start logging. Try logging timing advance, and short and long term (LT) fuel trims.
Or maybe you're experiencing wheel hop mixed with drivetrain slack over mixed pavement.
Old 09-22-2022, 05:18 PM   #6
GJR726WY
I'm having a hard time suspecting the engine with there being no CELs. I would really think the ECU would have picked up on something if I can feel it the way I do. Is there a specific item to search for the OBD Reader and App? I'd definitely be willing to try it.
The roads are pretty crappy here ... Any way to test your second suggestion? I would love it to just be this, but I feel it's gotten progressively worse and more frequent, so I'm not sure.
Old 09-22-2022, 07:06 PM   #7
radroach
Drives: car
@GJR726WY I used an OBDlink bluetooth OBDII reader and "torque app" (usual recommended android phone app) to log various things from the car. You just point the app to all the different listed functions and tell it to log:
IAM ignition advance multiplier
long term and short term fuel trims
flkc and fbkc knock correction
AVCS logging
Old 09-22-2022, 10:24 PM   #8
soundman98
ProCrastinationConsultant
soundman98's Avatar
it usually takes quite a lot for the check engine light to come on.
i'm also suspicious of the coil packs/spark plugs-- aftermarket or otherwise. what plugs were used?
x808drifter (09-23-2022)
Old 09-23-2022, 02:06 AM   #9
Compelica
Compelica's Avatar
Drives: 86 GT
AVCS logging
Don't think Torque has those PIDs built-in, he may need OBD Fusion + addon if he wants to monitor those values.
Potential misfiring? If you hold the revs in neutral, do you get the aforementioned bucking?
DIY stuff at Compelica Works
Compelica is offline   Reply With Quote
Old 09-26-2022, 11:16 AM   #10
GJR726WY
No, not at all.
Everything that I read about coil pack malfunctions was producing a misfire CEL.
I used the OEM spark plugs when I changed them.
I've ordered an OBD reader, I will start logging as soon as it comes in.
I'm still at a loss because half the time the thing runs like a dream. I can't seem to pinpoint anything specific causing the issue ...
Old 09-26-2022, 11:54 AM   #11
dragoontwo
dragoontwo's Avatar
Have you tried with all traction control off?
The Following User Says Thank You to dragoontwo For This Useful Post:
soundman98 (09-26-2022)
Old 09-27-2022, 10:26 AM   #12
GJR726WY
On the way home from work yesterday it finally reared it's head worse than it has to date and popped a CEL. Misfire Cylinder 1 .... I can apparently just tell something is wrong long before the computer can.
Does anyone know of anything besides the coil packs/plugs causing these misfires? The plugs are OEM so I doubt it's them ... I'm hoping IP will warrant the coils, but somehow I doubt that as well ...
Old 09-27-2022, 11:11 AM   #13
Compelica
Compelica's Avatar
Drives: 86 GT
The misfiring was probably within the ECU's tolerance as a CEL is only lit when a misfire continuously happens and not one-off, as I recall.
Since it seems to be getting 'worse' - electrical or connection issue?
Old 09-27-2022, 01:08 PM   #14
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I believe it only pops a code when it detects so many misfires within a certain period.
I mean there are a lot of things that CAN cause a misfire, coil pack is a common one. I suggest moving the coil off #1 and swapping it with a different cylinder to verify the issue.
FS: TRD "D oval" exhaust, OEM engine mounts, "STi" Radiator Cap cover Dave-ROR Engine, Exhaust, Bolt-Ons 1 05-18-2020 04:34 PM
FS: Avant Garde M310 Matte Black 18" x 9" and 18" x 8" w/ Michelin Pilot Super Sports NvSnickers Wheels and Tires 2 04-04-2017 11:30 PM
"Clicking" or "knocking" caused by rear seat pull down lever. husker741 Issues | Warranty | Recalls / TSB 6 11-27-2013 03:30 PM
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 07:34 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 01:59 PM
