Old 09-22-2022, 04:04 AM   #1
siko232
Drives: BRZ S
Are the old Brakes pads options such as in this URL compatible with the new 2023 BRZ?
https://www.subispeed.com/scp/subaru...Brake%20Rotors
I was wondering if the rotors, pad and skid are all straight slot between the 2011/22 to 2023 model?
siko232 is offline   Reply With Quote
Old 09-22-2022, 06:26 AM   #2
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
The standard brakes are compatible across all years. Just not the performance pack Brembos.
dragoontwo is offline   Reply With Quote
Old 09-22-2022, 09:58 PM   #3
Yes they are.
Are you looking for street or track pads?
Old 09-22-2022, 11:43 PM   #4
siko232
Drives: BRZ S
Yes they are.
Good question... I want to improve the performance on the track, without sacrificing too much on the st. Hopefully that make sense.
Old 09-22-2022, 11:44 PM   #5
siko232
Drives: BRZ S
Sorry what do you mean across all years? As in gears?
But yes... saw STI Brembo on the Subie website mentioned you need a different wheels or clearance.
Old 09-23-2022, 02:46 AM   #6
What is your driving experience level? Can you list the mods on your car and the track you run?
Old 09-23-2022, 06:32 AM   #7
dragoontwo
dragoontwo's Avatar
Model years. 13-22.
Old 09-24-2022, 07:33 PM   #8
siko232
Drives: BRZ S
Model years. 13-22.
It would be 2023, expecting delivery on the middle of December.
Old 09-24-2022, 07:35 PM   #9
siko232
Drives: BRZ S
I'm expecting a brand new car, won't have any mods on it. Thinking of upgrading pads and rotor first for track use. As I heard the OEM don't last more than a few laps.
Old 09-24-2022, 09:44 PM   #10
dragoontwo
dragoontwo's Avatar
They'll be the same, too.
Old 09-24-2022, 11:43 PM   #11
If you have track experience, definitely go straight to track pads!
Old 09-26-2022, 04:51 AM   #12
churchx
churchx's Avatar
Drives: 2014 GT86
In addition to switch to track brake pads do also change brake fluid to one of higher boiling temps.
If car is completely stock, consider in future changing alignment to more track oriented with more negative camber.
Old 09-26-2022, 09:33 AM   #13
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Just to add to what others have said. For autox, street set up is probably fine. For track, as @churchx pointed out, you need track pads and high temp brake fluid. Stock rotors are fine. In DE 1-2, I've been running Carbotech xp8's with Rockauto replacement rotors. There are many different track pads out there but no such thing as a street/track pad. @CSGMike is a good resource.
Old 09-27-2022, 10:54 AM   #14
churchx
churchx's Avatar
Drives: 2014 GT86
Originally Posted by blsfrs View Post
.. There are many different track pads out there but no such thing as a street/track pad. @CSGMike is a good resource.
Depends. If one is ok with extensive dusting and higher wear of expensive pads & rotors, then CSG C1 was good both on track & street. It braked consistently good at both uses, and didn't squeal. Just that i hated washing wheels every second day and as they cost a lot it seemed wasteful to "spend" them during daily driving.
2022 subaru brz, brake pads, caliper, rotor
AP Racing Brake kit — options for rear brakes Kulebrero1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 10-01-2022 07:17 AM
BRZ with PP brakes rotor replacement options Elliotw Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 10-16-2020 04:59 PM
Any street pads compatible with Carbotech XP8's? Captain Curt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 08-03-2016 02:31 PM
What's everyone doing on stock brakes, for pads? Nourdmrolnmt1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 05-15-2013 05:08 PM
Are there any decent brake kit options that are compatible with OEM wheels? DRACHENV6 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 11-15-2012 04:07 AM
