Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 09-21-2022, 03:22 PM   #1
X25
Sr. Spiritual Advisor
X25's Avatar
Drives: 2023 BRZ Premium
Beware: Perrin Tow Hook is.... not a "Tow Hook" : )
Recently purchased a Perrin Tow hook for simply loading the car on my super-low Futura 'kneeling' trailer.
This is what it says in description:
This product is NOT designed as a recovery hook! For any vehicle recovery needs, the OEM tow hook provided by the manufacturer, OR other suitable method as determined by the manufacturer or recovery company should be utilized. In no instance is the PERRIN Tow Hook designed for the purpose of recovering the vehicle! This product is designed for “show use” and for pulling the vehicle solely in a straight line. For example: Loading vehicle on to a “roll-back” style wrecker. The maximum total weight of vehicle and contents not to exceed 4000 lbs.
Since my angles are very kind to it, more so than an average roll-back trailer, I thought this would be fine to winch it with. Alas, it bent the first time I've used it, despite being very gentle to it.
This is the loading angle for me, using my trailer and BRZ.
This is an example roll-back trailer they're talking about
It bent from close to stem. I think they just need to upgrade it to stronger steel.
After this issue, painted the OEM unit to black and installed that instead; doesn't look bat at all : )
Anyway, if you intend to buy it, keep in mind you should probably never put any load on it.
'23 Subaru BRZ Premium Manual (Track Build Thread)
'22 Ford F150 Lariat Powerboost SuperCrew 6'5" 4x4
'21 Tesla Y Long Range AWD
'19 Corvette Z06 Z07 (Track Build Thread)
X25 is offline   Reply With Quote
The Following 4 Users Say Thank You to X25 For This Useful Post:
Jdmjunkie (09-21-2022), Midnightsky (09-23-2022), Teseo (09-23-2022), whataboutbob (09-21-2022)
Old 09-21-2022, 06:52 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
yep, that's 9/10's of the tow hooks on the market..
The Following 5 Users Say Thank You to soundman98 For This Useful Post:
DNAcomposition (09-21-2022), norcalpb (09-23-2022), PulsarBeeerz (09-21-2022), Teseo (09-23-2022), x808drifter (09-22-2022)
Old 09-21-2022, 07:47 PM   #3
DNAcomposition
DNAcomposition's Avatar
Drives: '23 BRZ Limited 6MT WRB
Was considering the Cusco front tow hook (SKU # 687 017 F). Anyone have experience as to whether that one is functional, or just cosmetic?
https://www.ftspeed.com/part/687-017...7#.Yyuh9XbMKUk
DNAcomposition is offline   Reply With Quote
Old 09-21-2022, 08:14 PM   #4
soundman98
soundman98's Avatar
most recovery pro's tend to say "if any recovery device doesn't have a load rating, assume it can't"
636 (10-01-2022), DNAcomposition (09-22-2022), FRSBRZGT86FAN (09-24-2022), Teseo (09-23-2022), x808drifter (09-22-2022)
Old 09-21-2022, 09:08 PM   #5
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
OEM tow hooks are cheap on eBay and salvage yards… and tend to be interchangeable within a brand. I bought 2 from an outback as I recall and painted them bright red. You want them to really be visible for both your shins and the recovery driver!
Originally Posted by drewbot
Pull out
nextcar is offline   Reply With Quote
The Following User Says Thank You to nextcar For This Useful Post:
Old 09-22-2022, 02:36 PM   #6
Interceptor777
Interceptor777's Avatar
Drives: 2022 BRZ, 1999 "touge-spec" Miata
At least we know who to make fun of!
Interceptor777 is offline   Reply With Quote
The Following User Says Thank You to Interceptor777 For This Useful Post:
alphasaur (09-28-2022)
Old 09-22-2022, 02:54 PM   #7
And for some the street cred while parked in a Walmart lot with a bunch of lowered widebody but mechanically stock cars!
OkieSnuffBox (09-25-2022), Teseo (09-23-2022), x808drifter (09-23-2022)
Old 09-22-2022, 02:55 PM   #8
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The Raceseng is a nice part, I have had to use mine before It has an interchangeable end to mount the license plate. Can't beat the OE tow hook them, people practically give them away.
Old 09-22-2022, 03:03 PM   #9
nextcar
And as an added bonus, if you are in a parking lot fender bender, they can both puncture the bumper cover or body panel of the car you hit, while at the same time transferring the impact directly to your frame! Best of both worlds
Pull out
The Following 6 Users Say Thank You to nextcar For This Useful Post:
Midnightsky (09-23-2022), pope (09-23-2022), soundman98 (09-22-2022), Tcoat (09-22-2022), Ultramaroon (09-22-2022), x808drifter (09-23-2022)
Old 09-22-2022, 03:09 PM   #10
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
They actually screw into the f/r crash bar, not the actual chassis.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
Old 09-22-2022, 03:19 PM   #11
Ultramaroon
not playing cards
Ultramaroon's Avatar
Ah, yes, but they do so directly in line with the frame rail. It does change things.
soundman98 (09-22-2022), x808drifter (09-23-2022)
Old 09-22-2022, 07:49 PM   #12
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
If the incident damaged the frame rail, I would say you got bigger problems to deal with.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
soundman98 (09-22-2022), Ultramaroon (09-22-2022), x808drifter (09-23-2022)
Old 09-22-2022, 08:11 PM   #13
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Does what it says on the box I guess.
Can't get up in their face about it if you use it anywhere but instagram.
The Following 2 Users Say Thank You to bcj For This Useful Post:
Old 09-22-2022, 09:41 PM   #14
Vertigyn
Drives: 2022 BRZ 6MT Limited
Got the Raceseng ones and they worked great when my engine blew. Track support used it, tow company used it, still good to go less a little paint on the loop.
Vertigyn is offline   Reply With Quote
FS: Extra OEM tow hook, cut BRZ tow hook covers skylinekin Exterior Parts (Aero, Lighting, Etc.) 4 09-20-2018 11:39 PM
WTT: Perrin 3" Catted Front Pipe + 3" Perrin Resonated Exhaust for 2.5" Setup projek_01 Canada Classifieds 3 03-03-2016 01:45 PM
Local "tuners" - BEWARE!! sav AFRICA 15 01-23-2016 06:09 PM
FS: Perrin tow hook license plate holder zuldajin Exterior Parts (Aero, Lighting, Etc.) 2 03-05-2013 06:32 PM
FS: Perrin tow hook license plate holder zuldajin Canada Classifieds 2 03-03-2013 09:13 AM
