| BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ |
Drives: 2023 BRZ
Regular maintenance suggestions for second gen twins?
A year or two ago Counterspace Garage published a great guide to maintaining track-driven cars. What, if anything, should be done differently for second generation twins?
Are the recommended fluids the same? @CSG Mike
Director of Rocky Mountain 86CUP
| The Following 2 Users Say Thank You to Pat For This Useful Post: | JusTheG (09-04-2022), Stonehorsw (09-01-2022) |
#2 | |
I've been doing trans rather frequently, as it drains thin with any hard driving. |
Drives: 2023 BRZ
Hoping to go through fewer transmissions on the second gen car, huh?
![]() Is there a way to analyze the tranny fluid like one might do for engine oil at Blackstone? Or maybe some other more scientific way to determine appropriate transmission fluid change intervals?
Send it off to the lab, but when it drains like water and grey, you don't need a lab to tell you the end result.
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | Tcoat (09-01-2022), x808drifter (09-02-2022) |
#5 | |
Drives: 2023 BRZ
I checked Blackstone's website and it says: "Can I get a TBN on my ATF? Well, you could, but it wouldn’t mean very much. The TBN is based on the level of calcium sulfonate and magnesium sulfonate in the oil, and transmission oil doesn’t have much of it. We can, however, run a TAN (Total Acid Number) on your transmission oil." and "Can you analyze my transmission fluid and differential fluid? Yes. The kit is the same and the cost is the same. We also sell pumps for drawing samples."
Drives: 22 BRZ
I did a transmission fluid analysis on my Focus ST when I changed it for the first time at 36k.
Everything was fine though a few metals were on the high side of their numbers which they attributed to their numbers averaging 16k per trans fluid change and the fact that mine was in the car since new for more than double that amount of miles.
#7 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Tcoat (09-02-2022) |
This is a no brainer to me. Especially on an AT where you can literally boil the fluid in a real hurry.
Oh god now all I can smell in my head is burnt ATF!
| The Following User Says Thank You to Tcoat For This Useful Post: | JusTheG (09-04-2022) |
Drives: 2022 BRZ sport-tech
Same fluid as the gan1? I beleive the specs changed for the gen2 (thinner).
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ Current: 22 BRZ, 00 S2K - #0220 |
#10 |
Drives: 2023 BRZ
A transmission cooler. Duh. Of course.
I don't remember many people using a tranny cooler on manual 86s. What can you tell us about that? I presume you guys have tested some things. Overall I think 86s are pretty reliable and easy to live with, even with track use. The one big exception in my experience is the transmission. If I could do something to confidently extend the life of it I would seriously consider it. But I understand a tranny cooler may only be part of the solution (i.e. flexing of the housing, etc.). I don't see any transmission cooling options on the CSG website.
#11 | |
Drives: 2023 BRZ
According to the owner's manual the car is filled with LV 75W at the factory, but also says API GL-4 SAE 75W can be used. It goes on to say, "However, using this type of oil will increase fuel consumption. [and] the following may be experienced: The overall performance and function of the transmission may be adversely affected. Rattling noises may occur during idling and fuel consumption may increase." I don't know a lot about these fluids, but it sounds to me like Subaru says we should use 75W manual transmission oil. I think that's different than 75W-90, which is what everyone seems to run in the first gen cars. Hopefully someone can chime in here with better knowledge than what I have. I'm guessing CSG recommends 75W-90 for more protection (i.e. thicker film) in high-stress applications. Also, now I fear I'm turning into one of those people that argue about which engine oil is best. Oh God help me. I really just want to know how to get the longest life out of my transmission and differential, knowing the car sees 0* Fahrenheit temperatures in addition to 100* Fahrenheit track days.
| The Following 2 Users Say Thank You to Pat For This Useful Post: | DarkSunrise (09-02-2022), Desertnate (09-07-2022) |
#12 |
Drives: '20 Tundra, '84 SpecE30
#13 |
Drives: WR Blue Pearl 2022 Subaru BRZ
I've seen pics of the diff oil draining grey after heavy track use, but not the tranny.
Interested to hear more about this. |
| The Following User Says Thank You to Blighty For This Useful Post: | Pat (09-04-2022) |
| looking for twins-focused shops - track prep/maintenance | burzze | New England | 9 | 06-20-2020 11:51 AM |
| Maintenance Suggestions - new BRZ | fxo | BRZ First-Gen (2012+) — General Topics | 15 | 03-16-2019 10:01 PM |
| Diff oil ls or regular | Mr_YUzU_FRS | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 4 | 04-17-2017 08:18 PM |
| regular maintenance at dealer with a tune | WhenzLunch | Scion FR-S / Toyota 86 GT86 General Forum | 19 | 02-13-2016 04:11 PM |
| use regular gas? | Sirnice | Scion FR-S / Toyota 86 GT86 General Forum | 85 | 09-29-2012 08:25 AM |
