Old 08-25-2022, 07:13 AM   #1
colin88
Drives: 2013 Toyota 86
P1263, p0304 after spark plug change
Have changed spark plugs as I have a misfire.
I'm waiting on new coilpacks but was hoping the car would get better with new plugs.
All I have done is change the spark plugs and straight after went for a test run. A full throttle pull in 3rd got a few pops then nothing, almost like someone turned the key off.
I managed to get it home by resetting / clearing the codes but it only gives me 2 seconds of throttle before going into limp mode again.
Any help is much appreciated
Sent from my SM-S908E using Tapatalk
colin88 is offline   Reply With Quote
Old 08-25-2022, 12:37 PM   #2
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Did you replace and retighten the bottom bolt on the DI computer?
Old 08-26-2022, 06:16 AM   #3
colin88
Sure did.
Old 08-26-2022, 09:48 AM   #4
blsfrs
blsfrs's Avatar
If you haven't already done so, check the connections to the DI computer and to the direct and port injectors, esp #4. There are 2 other ground straps. Check them too.
Spark Plug Change from Under The Engine? hachigoku Engine, Exhaust, Transmission 5 10-03-2021 10:08 AM
DIY: Spark Plug Change thekevinvo DIY (Do-It-Yourself) Guides 22 12-15-2020 04:41 PM
Helpful DIY Spark plug change video DTMdreaming Engine, Exhaust, Transmission 13 10-17-2020 08:55 PM
P1261 and 1262 after spark plug change Remmenator Issues | Warranty | Recalls / TSB 2 05-20-2020 04:09 PM
Spark plug change - dealership price? wparsons CANADA 47 05-08-2019 06:48 AM
