Drives: Gt86 2013
Hey Guys i am still struggling with my engine. I rebuilded my car after an engine fire. The car starts runs ruff and way too lean. I have tried so many things and checkt everything i could think of! I hope you have some ideas what i can check next because i am at my limits!
I checked: Fuel: - Pressure in both lines to the engine (around 4 bars) - Highpressure for DI is like it should be (looking at the values in my app) - All injectors are opening. I checked the port injectors they also are spraying i a nice pattern. Air: - The intake side is completle sealed. I checkt it with positiv pressure. - The Exhaust system is mostly seald no leaks till the first muffler. - My MAF is sending some infos to the ECU - Also dose the MAP - the Evap and PCV are working fine Electric: Bought a AFR gauge to have a vision on the AFR New parts: -Engine ECU -Body ECU -DI ECU -Gateway ECU (think it is the Body ECU) -Wireharness (Engine & enginebay(the one with the big fusebox)) -O2 sensor I will put 2 videos on this Post. In one you can see the AFR and on the other you can see the ruff engine idle. I really need Your help and would be happy to hear any ideas unnessecary how crazy they are. PS: I had checked the timing because i feld bad about that. there i recocnized that the VVT from the Driverside exhaust camshaft was locked not in the right position. could that be a problem? i took it off twisted it to the right place and put it back on. Links: AFR: Ruff idle: https://youtube.com/shorts/jz2NYksQD4s?feature=share PSS: sorry for my english if anything isnt clear feel free to ask! |
| P0171 and P1170 codes when at low RPMs or idle | stockysnail | Issues | Warranty | Recalls / TSB | 35 | 12-22-2022 08:27 PM |
| Odd idle and P0171 and P1170 codes | dave- | Engine, Exhaust, Transmission | 0 | 09-26-2018 11:05 PM |
| Ruff R351 18x8 +40 & Kumho Ecsta AST 235/40-18 2000 Miles | ShaneLindley | Wheels and Tires | 7 | 07-11-2016 11:08 AM |
| FS: Ruff Racing R356 18x8 w/ Yokohama 225/40 18 | Dan@AWD | Wheels and Tires | 12 | 11-17-2013 11:10 PM |
| >>> 18" RUFF Racing 351 | 356 | 357 wheels - starting @ 710.00 shipped | speed depot | Wheels and Tires | 9 | 11-23-2012 06:54 PM |
