Old 08-19-2022, 04:54 PM   #1
shbamboo
shbamboo's Avatar
Drives:
Scraping Noise?
I recently did a TOB replacement, and when I put everything back it was smooth. Clutch felt better, and car ran smoother but now I encountered a new issue. I keep hearing this sound almost like a metal to metal scraping sound. Sounds like it’s by the passenger middle, by the firewall. It’s only when I’m on the highway going about 65-70mph, after I get off the highway it stops. When it’s happening I tried to downshift, and even put it in neutral but it’s still happening. Can anyone point me in the right direction? Kind of new to this also, sorry if I’m not very descriptive. I do have a video of the sound just don’t know how to post it on the thread
UPDATE: FIXED, loose clips on the heat shield loose causing it to rub
shbamboo is offline   Reply With Quote
The Following User Says Thank You to shbamboo For This Useful Post:
soundman98 (08-23-2022)
Old 08-20-2022, 01:47 AM   #2
shbamboo
shbamboo's Avatar
Drives:
BUMP
Old 08-20-2022, 03:31 AM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
Upload the video to imgur/Instagram/YouTube and link it to here.
I would check heat shields first
humfrz (08-21-2022)
Old 08-20-2022, 05:52 PM   #4
StraightOuttaCanadaEh
Wes
I used to get that on the highway and it turned out to be a broken under-bumper plastic cover. At highway speeds the wind would blow the broken flap downwards and had it scraping against the road. Also heard it during deceleration when the nose pitches. Probably not that, but just in case
Instagram: @gt86ws
The Following 2 Users Say Thank You to StraightOuttaCanadaEh For This Useful Post:
humfrz (08-21-2022), NoHaveMSG (08-22-2022)
Old 08-22-2022, 04:50 PM   #5
shbamboo
shbamboo's Avatar
Drives:
https://imgur.com/a/doHsl0h
This was on the freeway going about 62-65, and it just goes away. It doesn’t continue, but if I’m just riding on the streets it’s never heard.
Old 08-22-2022, 04:53 PM   #6
shbamboo
shbamboo's Avatar
Drives:
I might raise the car and double check make sure everything is secured. It’s weird because the noise just goes away after a bit, and it’s only on the highway. I will keep you updated!
Old 08-22-2022, 06:46 PM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Check the plastic pieces the skid plate attaches to with plastic rivets by the lower control arms. I wonder if they are fluttering and hitting at certain speeds.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
Spuds (08-23-2022)
Old 08-23-2022, 07:47 AM   #8
shbamboo
shbamboo's Avatar
Drives:
UPDATE: that was the issue, last night I raised the car and apparently I forgot to put the clips so they were loose. I jumped on the freeway to work hit 70 and it no longer made that noise.
Old 08-23-2022, 07:48 AM   #9
shbamboo
shbamboo's Avatar
Drives:
Thank you guys for the help!
The Following 2 Users Say Thank You to shbamboo For This Useful Post:
NoHaveMSG (08-23-2022), soundman98 (08-23-2022)
Old 08-23-2022, 10:55 AM   #10
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I've done that one before, so when I read the post I had an idea
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
norcalpb (08-23-2022), soundman98 (08-23-2022)
scraping/squeaking noise pulling away - Suspension? castroneves Issues | Warranty | Recalls / TSB 8 11-04-2021 11:07 PM
Rear brake scraping noise (Please help!) tobin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 09-29-2020 06:49 AM
Loud Sudden Rattling/Scraping Noise from Left Front Wheel revaholic Issues | Warranty | Recalls / TSB 2 05-21-2018 07:33 AM
Clutch scraping noise 8 six Scion FR-S / Toyota 86 GT86 General Forum 31 01-05-2015 02:39 PM
Scraping metal noise? Gost Issues | Warranty | Recalls / TSB 0 03-14-2013 09:11 PM
