Old 08-17-2022, 02:56 PM   #1
jacobe38
jacobe38's Avatar
Drives: frs
E85 Fuel Starvation Mod
Hello all,
I made a video to share my fuel starvation mod, hope this helps someone.
Like many of us I experienced pretty bad E85 fuel starvation on track, Verus Fuel door wasn't enough, and I wasn't ready to take the plunge on a surge tank. So I decided to try and look into the lifter pump solution.
While I was researching how to go about this, I couldn't find any write ups or guides like you usually can for just about anything you'd ever want to do to a car, and it slowed me down. So I decided if I was able to get it working I would try and make one to help people out.
Pasting video description:
This video goes over how I modified my fuel system to greatly reduce fuel starvation while running E85 at the track by installing a secondary fuel pump in the passenger side of the fuel tank.
It was successful but not perfect. I still fuel starve at 1/2 tank. But prior to this, I couldn't even do 5 laps without fuel starving despite going out with a 100% full tank. So for me it was hugely successful and enables me to use E85 when I effectively could not before. Your experience may vary.
I installed the Verus Fuel Door while I was NA and it helped a little bit but once I went FI it wasn't enough. I'm not ready to take the plunge on a surge tank and all that those entail, not to mention the cost. For about $100 and topping off between sessions I am very happy with this solution! I've done 5 track days now with this setup and so far so good. I'll come back and edit this if that changes.
Things I bought:
Submersible Rubber Fuel Hose, 8mm ID for the pump I chose. I got two feet and trimmed a little.
http://www.radiumauto.com/Submersibl...Hose-P831.aspx
Hose Clamps, (18-0031). You could probably use whatever, but I liked this design
http://www.radiumauto.com/Hose-Clamps-P894.aspx
Fuel Pump. I liked this for the low current draw, price, and size. It's also designed for this application.
https://deatschwerks.com/products/9-110-1055
Video of me fuel starving on track:
Feedback and ideas for improvement welcome!
jacobe38 is offline   Reply With Quote
The Following 7 Users Say Thank You to jacobe38 For This Useful Post:
CSG Mike (08-18-2022), DocWalt (08-17-2022), gen3v8 (08-17-2022), jflogerzi (08-17-2022), NoHaveMSG (08-17-2022), RedReplicant (08-17-2022), villainous_frx (08-18-2022)
Old 08-17-2022, 07:46 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Probably adaquite for us that are NA. Nicely done.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
jacobe38 (08-17-2022)
Old 08-17-2022, 09:33 PM   #3
jacobe38
jacobe38's Avatar
Drives: frs
I agree, and thanks!
The Following User Says Thank You to jacobe38 For This Useful Post:
DocWalt (05-25-2023)
Old 08-17-2022, 09:55 PM   #4
jflogerzi
jflogerzi's Avatar
Booked marked and will be looking at this in the future
Sent from my Pixel 6 using Tapatalk
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
Fuel Starvation geraldjust Tracking / Autocross / HPDE / Drifting 17 06-30-2022 01:08 PM
Possible cure for fuel starvation blsfrs Engine, Exhaust, Transmission 0 09-11-2021 10:02 AM
Fuel Starvation? Lunatic Tracking / Autocross / HPDE / Drifting 37 03-28-2018 11:47 PM
How to fix fuel starvation on left hand turns - Verus Fuel Door FT-86 SpeedFactory Engine, Exhaust, Transmission 3 08-21-2017 03:22 PM
Fuel Starvation feldy Tracking / Autocross / HPDE / Drifting 1 06-09-2012 10:14 AM
