Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > GR86 General Topics (2nd Gen 2022+ Toyota 86)
GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86
Old 08-06-2022, 12:15 PM   #1
Ghost of Akina
Ghost of Akina's Avatar
Drives: DE5 Integra Type S
License Plate Mount?
Anybody know what this is?
I have noticed it on photos of a lot of JDM GR86’s and BRZ’s?
At first I thought plate adapter but the GR86 has divots for both JDM and USDM plates…
Just thinking of a better way to mount the plate with out it sitting right on the paint.
"Precision without speed is empty, speed without precision, chaos."
Ghost of Akina is offline   Reply With Quote
Old 08-07-2022, 01:05 PM   #2
mycrors7
mycrors7's Avatar
Drives: zd8 brz
In japan, removing your plate from your vehicle is illegal. It can’t be removed or tampered with unless the vehicle is sold
For that reason, rear plates are on a pivot point so you can still remove your rear bumper without having to go to a someone who has access to remove the tamper-proof seal on the bolt
mycrors7 is offline   Reply With Quote
Old 08-07-2022, 01:34 PM   #3
Spektyr
Drives: GR86
What I did was I put adhesive foam feet, like you put on the bottom of something to stop it sliding around, on all four corners of the underside of my license tag. Then I screwed it onto the car.
That way if the plate ever vibrates for some reason there's a bit of a cushion between it and the paint. Granted, if dirt or grime gets under there it could abrade the paint a little (or a lot) but it will still be FAR less damaging than if it were metal-on-paint.
Spektyr is offline   Reply With Quote
Old 08-07-2022, 05:57 PM   #4
justinco
justinco's Avatar
Drives: 2022 GR86
I get these carbon fiber plate frames that have a foam backing for the license plate, for all my cars. Bit safer than the metal plate vibrating or brushing up the paint.
justinco is offline   Reply With Quote
Old 08-07-2022, 08:50 PM   #5
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
+1 to the foam backing sticker. I used this one on all my license plates: https://www.amazon.com/gp/product/B07ZZJH39Y/
I only used the foam sticker, not the hardware, as the dealers already took care of the hardware for me (for better or worse).
Follow the build thread for my GR86!
timurrrr is offline   Reply With Quote
Old 08-09-2022, 06:16 PM   #6
rande
rande's Avatar
Drives: Spyder, MR2, FRS, Tundra
Just put a few dabs of silicone on the back of the plate.
rande is offline   Reply With Quote
Old 08-09-2022, 10:54 PM   #7
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Rubber Baby Buggy Bumpers
Rear license plate mount dragoontwo BRZ Second-Gen (2022+) — General Topics 1 12-11-2021 04:38 PM
License Plate Mount OEM. 2 Available abevil Exterior Parts (Aero, Lighting, Etc.) 1 02-24-2019 01:39 PM
Grimmspeed License Plate Mount Cade01 Exterior Parts (Aero, Lighting, Etc.) 14 03-18-2014 01:00 PM
front license plate mount? Jeong Cosmetic Modification (Interior/Exterior/Lighting) 16 02-13-2014 10:54 PM
License Plate Mount calidus Cosmetic Modification (Interior/Exterior/Lighting) 2 02-10-2014 12:44 PM
