Click Here
PLM UEL Header Experience
Having difficulty finding what I would call reputable reviews on the PLM header. Made the mistake of ordering it before doing any extensive research and have seen a bunch of complaints surrounding overall fitment and the quality of hardware that accompanies the piece. Just looking for any input from people that have it on their 86.
Drives: Crapcan
PLM doesn’t have a good rep and you won’t find much about them because they knockoff other companies parts. I believe their UEL was a knockoff of the early JDL UEL.
Click Here
Welp. At least I know now. Thanks
The Fail Boat
Drives: CWP S.B.
#6 | |
Click Here
The general complaint seems to be the gaskets and hardware, so upgrading to Grimmspeed gaskets seems to somewhat resolve the issue. |
#7 | |
The Fail Boat
Drives: CWP S.B.
Drives: Crapcan
Live and learn. If you are having issues getting it to seal I recommend remflex gaskets.
https://catalog.remflex.com/
#9 | |
Click Here
Mind you, I can't know until at least Thursday anyway. That's when it's supposed to arrive. |
#10 | |
Drives: Crapcan
#11 |
Click Here
Noted. Did some more reading and OEM gaskets will work so I'm running with that as a short-term (unless it just works). The bolts that come with it are designed to work with the PLM overpipe so need to figure out an alternative for that. Was hoping I could find dimensions somewhere but I'll have to wing it, I guess. Can't find anywhere that can confirm if I can reuse the original hardware or not.
#12 | |
Drives: Crapcan
I believe the stock overpipe is studded where it mounts to the header. So if you are using a stock overpipe just reuse the stock hardware. With aftermarket overpipe, they are usually 10mm, or 3/8(9.525mm) hardware. I have been running 3/8’s for years with no issues. Gives me more locknut options.
#13 | |
Click Here
#14 |
Click Here
Just finished getting it installed. Had to be worked into place because one of the flanges are off about half an inch but I was able to get it to work. I damaged the OEM header to overpipe gasket during the uninstall so I used the one with the kit as a temporary measure. No surprise that it's leaking but it is a bit loose still. I'll see if I can find just that gasket and get it swapped out soon. Given how difficult it was to force the header into place, however, I don't know if it's ever coming off lol.
As far as the actual bolt assembly is (my main concern if you scroll up a bit), the studs are actually part of the factory header assembly, so use of different hardware is required. However, the hardware with the kit seems to be fine, so I'm not sure what the problem was supposed to be. Overall, I updated to stage 2 on my OFT and the car feels great. I definitely feel more grunt in the mid range. Slight leak that is audible but I'm overall happy with it. It's ever so slightly louder than stock so I can confidently recommend it to anyone that doesn't have emissions testing in their state and want a slight choppier exhaust note. |
| Does anybody have personal experience with the HKS UEL header? | DigitalVeil92 | Engine, Exhaust, Transmission | 9 | 06-20-2020 07:36 PM |
| dimpled intake/header (what's your thoughts/experience?) | Escobar89 | Engine, Exhaust, Transmission | 40 | 10-05-2018 08:01 PM |
| My experience with Shiv & his products at Open Flash Tablet / Open Flash Header | TouchMyHonda | User/Vendor/Sponsor Reviews, Feedback, Comments | 5 | 10-23-2015 09:57 AM |
| RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP | NickFRS | Engine, Exhaust, Transmission | 44 | 04-19-2014 05:42 PM |
