Old 07-24-2022, 05:20 AM   #1
sam p
Drives: 2012 Toyota 86 GTS
Damage to front left wheel and lower control arm
Toyota 86 2012 GTS (front wheel damage) help
Recently hit a curb and rock under the front left hand side wheel of my 86, resulting in a fair bit of damage, i was wondering if anyone could assess these photos and let me know anything more than i do myself. Thank you.
sam p is offline   Reply With Quote
Old 07-24-2022, 10:51 AM   #2
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Are we looking at the passenger side: ie Right front? A minimum would be replacing the lower control arm, spindle, tie rod, sway bar link, and strut. Being a 2012, you would probably replace both fronts, if not all 4 struts. That's just the damage that's seen in the pictures. I can't tell if anything else is bent. To be honest, if you are asking these questions, you probably should take it to a shop.
Old 07-24-2022, 11:15 AM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
It's going to need and alignment anyways, I would say least get a shop to look it over
Old 07-24-2022, 08:23 PM   #4
sam p
Yeah of course, thanks for the help, it’s the front left side, so being in Australia, that is the passenger side. I’ll have to get it into a mechanic of course, I was just curious to what y’all thought, as I don’t have much experience, the car is undriveable and the wheel was severely worse when I hit the curb a few days ago. Do you think there’s any chance of further damage, unseen in the photos. And what exactly do you mean by replacing both sides because it’s a 2012? Thank you for your reply.
Old 07-24-2022, 10:02 PM   #5
blsfrs
blsfrs's Avatar
My apologies, I didn't realize right side and left side of cars were different in Aus. vs US. I suggested replacing both struts given the age of the car. A new strut would probably be stiffer than one that's 10 years old with a bunch of kilometers. Best to keep things balanced. Of course, you might find used parts with similar age and mileage in which case there might not be much difference.
It's hard to know if frame/crossmember is bent where the lca attaches. Someone experienced with suspensions may be able tell by looking at it in person.
Old 07-24-2022, 10:51 PM   #6
sam p
Yeah all good, thank you, so is there any chance it’s written off, or like an expensive job?
Old 07-24-2022, 11:22 PM   #7
soundman98
soundman98's Avatar
it really depends on if that curb/rock damaged anything else underneath the vehicle
Old 07-24-2022, 11:53 PM   #8
sam p
Alright thank you heaps.
Old 07-27-2022, 09:01 AM   #9
Desertnate
Spelling Impaired
Drives: 2022 BRZ Limited WR Blue
With that type of damage and the possibility of bent tie rods, I'd probably take a look at the steering rack too to make sure it isn't damaged. The force of the impact may have been transmitted "down stream" past the tie rods into the rest of the steering system.
Desertnate is offline   Reply With Quote
Need A Left Front Control Arm Near Portland (PIR) Today Totemo_Hayai Northwest 0 07-11-2020 06:50 PM
Need left driver side lower control arm jrsd1 Want-To-Buy Requests 0 08-21-2015 11:38 AM
WTB: OEM Control Arms: Front Left & Back Left norcalpb Want-To-Buy Requests 0 02-26-2015 08:55 PM
TRD Style ABS Front Bumper Lip, CFW Trunk Spoiler, LH Lower Control Arm Front STS-V Want-To-Buy Requests 0 03-18-2014 03:42 PM
WTB: Front Lower Control Arm and Rear Upper Control Arm YDNA Brakes, Suspension, Chassis 0 11-10-2013 04:40 AM
