Drives: 2013 subaru brz
replacement studs for ichiba wheel spacers v2
hi folks, anybody know what kind of studs the ichiba v2 wheel spacers use? tire shop damaged a couple nuts and i ended up with a broken stud on two spacers. the thread is the same as the stock stud, but at least the knurl is a different width. not sure how to approach getting a like for like replacement. i have 20mm in the front and 25mm in the back. both studs appear to be the same length. thanks in advance
| Ichiba 5mm Spacers w/Studs | XanRules | Wheels and Tires | 14 | 04-03-2018 03:10 AM |
| Ichiba 10mm hubcentric spacers with extended studs | protpibe | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 05-01-2015 03:21 PM |
| Eibach Sport Pro Springs, 10mm/5mm Hub centric Spacers, Ichiba extended studs | bryan767 | Brakes, Suspension, Chassis | 9 | 04-26-2015 07:40 PM |
| FS: 20mm and 25mm Ichiba wheel spacers | Jyn | Brakes, Suspension, Chassis | 12 | 11-17-2014 04:54 PM |
