Old 07-09-2022, 02:16 PM   #1
ZDan
ZDan's Avatar
Drives: '23 BRZ
215/45-17 Yok A052, on 17x9 or 17x7.5?
I blistered the outside tread of the outside front at Palmer MA in a few places last weekend. I'd like to replace a couple of tires before heading to Thompson CT next weekend. Unfortunately the only size A052 I could run that's available (at Tire Rack anyway) is 215/45-17. I don't mind running this size at the back of the car, question is which wheels, factory 17x7.5, or 17x9 track wheels.
I normally run 235/45-17 or 245/40-17 on 17x9. 225/45-17 I'd have no qualms running on 9" width. 215/45-17s and I'm on the fence here...
A052s do like a little bit of stretch, I'm guessing 215 on 9" might be beneficial for grip and lap times. But it is an inch wider than max recommended...
Opinions?
Old 07-09-2022, 02:32 PM   #2
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Opinions?
215 on a 9' wheel is pushin it
The Following User Says Thank You to TommyW For This Useful Post:
ZDan (07-09-2022)
Old 07-09-2022, 03:17 PM   #3
ZDan
ZDan's Avatar
Drives: '23 BRZ
Yeah, I'm totally comfortable with 225/45-17 on 9", not so much 215...
I may hold out, I do have other options with totally worn-slick set of 235s, could mount the best of those and rotate the outside front throughout the event to forestall/minimize blistering...
Hopefully the set of 245/40-17 RE71RS I ordered way back when will actually show up for this event, then I'd be A-OK...
Old 07-09-2022, 04:06 PM   #4
Kelse92
At the track
Drives: '14 FRS - Former e92 M3
Maybe get some Nankangs instead?
#ladydriven Nasa TT4 FRS // JRZ RS Pro // Karcepts Sway Bars // K24 Swap (in Progress) // AP Endurance BBK // Cobalt Friction brake pads // Safeplace Auto
Kelse92 is offline   Reply With Quote
The Following User Says Thank You to Kelse92 For This Useful Post:
ZDan (07-09-2022)
Old 07-11-2022, 12:49 AM   #5
jflogerzi
jflogerzi's Avatar
Look at some cheaper 660s
Sent from my Pixel 6 using Tapatalk
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
ZDan (07-11-2022)
Old 07-11-2022, 12:36 PM   #6
ZDan
ZDan's Avatar
Drives: '23 BRZ
New RE71RS are supposed to arrive at Tire Rack's CT warehouse tomorrow, fingers crossed... Nankang CR-1/CR-S or Falken RT660 are good recommendations but I'd like to stick with A052s for known-awesome wet lap times in addition to dry.
jflogerzi (07-11-2022)
Old 07-11-2022, 01:47 PM   #7
jflogerzi
jflogerzi's Avatar
If you needed something in a pinch. Dry and optimal conditions they are pretty close. BTW be sure to post your thoughts on the new RS's
ZDan (07-11-2022)
Old 07-11-2022, 03:41 PM   #8
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
215's on a 9" wheel (IMO) is nuts. That's 'stancy boi' stretch. I ran 225/45/17's on the stock 7.5" PP wheels and they're just about square as can be. A052, RT660, and RE-71. For a 9" wheel, it's 245's all the way.
If it boils down to not being able to get A052's, I'd rather be using a 245 RT660 vs a 215 A052.
cmiovino is offline   Reply With Quote
The Following User Says Thank You to cmiovino For This Useful Post:
nathand (07-11-2022)
Old 07-11-2022, 06:02 PM   #9
ZDan
ZDan's Avatar
Drives: '23 BRZ
For sure I'd run 225/45-17 on 9", but yeah, I decided that if I was to get a couple of 215/45-17s they'd go on the factory 17x7.5 wheels.
Was on the fence about that. I'd get a weight break with the 215s on one end of the car and not have to add as much ballast. And also I do want the much greater wet grip of the A052s vs. the RT660.
But I just got notification that brand new 245/40-17 RE71RS are at the warehouse in CT So I'm totally good for Friday/Saturday at Thompson
jflogerzi (07-12-2022)
Old 07-13-2022, 08:21 PM   #10
SCFD
Definitely go with the 17x7.5 wheels. I would not want improperly fitting tires on a car seeing any track use.
SCFD is offline   Reply With Quote
The Following User Says Thank You to SCFD For This Useful Post:
ZDan (07-14-2022)
You A052, first laps fastest? ZDan Tracking / Autocross / HPDE / Drifting 12 09-16-2021 12:22 PM
Nankank CR-1 vs. A052? ZDan Tracking / Autocross / HPDE / Drifting 34 03-30-2021 05:16 PM
Would 245/40R17 A052 fit on 17' BRZ with OEM struts? Samba Tracking / Autocross / HPDE / Drifting 11 01-30-2021 02:18 PM
Rays Gramslights 57DR 17x9.0 +35mm Gun Metal Vs Work Emotions 17x7 + 35mm Bronze jflogerzi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 02-09-2013 07:09 PM
