Old 07-08-2022, 11:20 AM   #1
Leviticus Ezra
Leviticus Ezra's Avatar
Drives: 2017 BRZ w/Performance Package
Question 2017 Turbo BRZ Misfire Issue
Hello everyone,
I've been chasing a misfire issue on all cylinders for a while now and just cant seem to figure out what is causing it.
Briefly this is what I have done power wise:
Works Motorsport Stage 2 Tuner kit
DW700cc injectors
DW65C Fuel Pump
Delicious Tuning flex fuel kit w/ MK1+
NGK Racing Spark Plugs
Delicious Tuning Coils
3 Bar Map sensor
Delicious Tuning EBCS
Radium Dual catch cans
GFB diverter/bov
And a few other things...
The car ran great after the initial tuning process, going from E85 to 93 was a breeze! Then one day, going to E85. The car started differently, and racked up a few misfires on each of the cylinders. The most was 20 on cylinder 4. What really throws me off, is it's not just cylinder 4. It seems to be all of them that misfire.
The misfire is very random, and doesn't just effect one cylinder more than the other. I could start the car after sitting, and it might rack up more misfires on cylinder 2 that time than any of the others. Like I said. It's just been random. One day it could run fine, with very few misfires, only upon fire up. Then other days, it could be really bad to the point where it's undrivable.
It got to the point where one day, I kept turning the car on and off to get it to run for just a few minutes at a time before it started to act up. Then it just all out quit on me and wouldn't stay running at all.
I sent my flex fuel kit in to get RMA'd and I had a faulty pressure regulator. So they swapped it out for a new one and that seemed to do the trick... Momentarily. After swapping the new sensor, it ran for about 2 days. Then the issues came right back and seemed to be only getting worse.
I've been back and fourth with my tuner, with very little success as to what could be causing this. He stated that there have been some issues with Delicious Tuning products, but I don't want to rule them out just yet.
The cars got good fuel pressure and the ethanol content reads perfectly. Which was what I was having issues with previously. But now that the flex fuel kit should be fixed, the misfires are still occuring.
Any information on this would help greatly,
Thank you
Leviticus Ezra is offline   Reply With Quote
Old 07-08-2022, 08:57 PM   #2
Grady
Grady's Avatar
We need a log when the car is acting up. It may point to the culprit or just help us eliminate what it is not.
PLEASE reply if you have had an identical or similar misfire issue empower-auto Issues | Warranty | Recalls / TSB 12 07-01-2026 08:24 PM
UCUTEK AFR issue on the 2017+ BRZ/86 Vloood Software Tuning 21 04-05-2020 03:34 PM
2017 brz radio issue Jmk91 Electronics | Audio | NAV | Infotainment 2 11-17-2019 08:11 PM
2017 Taillight melting issue norcalpb Cosmetic Modification (Interior/Exterior/Lighting) 1 12-08-2018 10:59 PM
2017 Key Not Detected issue tfp Issues | Warranty | Recalls / TSB 30 04-01-2018 12:28 AM
