Old 07-03-2022, 11:48 PM   #1
gantonski
Drives: 2015 BRZ
Question Supercharger - Sprintex S5 210 vs SPS model? Differences?
Im seeing a price difference but on ft86speed website the descriptions are the same - unless I missed something.
Can anyone help clear this up for me??
Thanks!
gantonski is offline   Reply With Quote
Old 07-04-2022, 09:11 AM   #2
Brz-123
Former has Sprintex S5-210 1.0L twin screw compressor.
Latter has S5-335 1.5L supercharger.
So depends on if you want to keep a stock engine and boost where you need the former or want to really up the game and forge the rods and add the rest of the supporting mods like fuel pump, bigger injectors etc in which case you need the latter.
Brz-123 is offline   Reply With Quote
Old 07-04-2022, 11:54 PM   #3
86TOYO2k17
Drives: 2017 toyota 86
Incorrect.
Both 210 and 335 have sps upgrade option.
Sps upgrade is a special coating on the rotors. It should make the unit roughly 8% more efficient/ more boost.
If you plan on going 69mm pulley and still wanted to squeeze just a little more the sps might be the way to go, however at that point a 335 unit with the largest pulley IIRC 85mm pulley makes about 14psi would probably be a better option. If you had plans to build the block and wanted to push a 335 unit as much as possible the sps upgrade would be worth it at that point IMO.
Old 07-05-2022, 01:06 AM   #4
gantonski
Drives: 2015 BRZ
Thanks guys!
Old 07-05-2022, 05:08 AM   #5
Brz-123
Originally Posted by 86TOYO2k17 View Post
Incorrect.
Thanks Chief, learn something new everyday.
price difference, sprintex, sprintex 210, supercharger
Any major differences between all model years? Sasquachulator Scion FR-S / Toyota 86 GT86 General Forum 15 07-25-2018 06:01 AM
Later model-year differences? Qwimby1 Scion FR-S / Toyota 86 GT86 General Forum 22 07-14-2018 10:05 AM
California Model differences? TurnOne Engine, Exhaust, Transmission 21 09-29-2012 01:02 PM
FR-S vs. BRZ Differences - Engine/Model Codes Flipside909 Scion FR-S / Toyota 86 GT86 General Forum 5 05-07-2012 02:26 PM
Model Differences - FR-S:BRZ Limited:BRZ Premium merlin2111 BRZ First-Gen (2012+) — General Topics 14 03-22-2012 04:09 PM
