Old 06-28-2022, 08:46 AM   #1
MichaelHu
Drives: 2017 Subaru BRZ
Catless Front Pipe Install Made Car Sound Like Trumpet
Hi everyone,
First time posting here. I have a 2017 Subaru BRZ, and recently put on an Invidia catless front pipe. I have the Tomei UEL headers and an Invidia N1 catback on the car as well. When I floor the car now it sound a bit like a trumpet, and in my opinion it does not sound great and I want a different sound.
I am trying to find a solution to the "trumpety" sound, the volume is fine but I want to fix the quality of the exhaust note. Since the over pipe on my car is the only stock part of the exhaust and has the smallest diameter, could that be the part that's giving me the bad sound? Or should I look into a different catback system than the N1? Does anyone run similar setups and how was your experience with it?
Thanks in advance.
MichaelHu is offline   Reply With Quote
Old 06-28-2022, 09:05 AM   #2
StraightOuttaCanadaEh
Wes
1. Different from N1
2. Resonators are key. Look for front pipes and catbacks with nice fat resonators in them
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
alphasaur (06-28-2022)
Old 06-28-2022, 09:13 AM   #3
MichaelHu
Thanks for the response. So I guess the N1 is the main culprit for the trumpety sound hey? I do have one resonator in my entire system right now and that's on the N1's mid pipe, so yeah maybe I do need to switch the N1 altogether. The smaller diameter overpipe doesn't matter in this case then?
Old 06-28-2022, 09:17 AM   #4
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
Originally Posted by MichaelHu View Post
Hi everyone,
Thanks in advance.
That is because the N1 is one of least better sounding catback system when paired with everything being catless.
Get a resonated F.P or high flow cat. Switch to either HKS, Greddy, Borla, TRD, CSG, MXP catback systems.
In terms of sound the O.P does very little, in terms of performance, is only important when going F.I.
Old 06-28-2022, 09:20 AM   #5
Wes
no, it'll just make it louder and increase rasp
Instagram: @gt86ws
Old 06-28-2022, 09:40 AM   #6
MichaelHu
Will do, gonna try to find one of those catbacks to switch onto then, will keep updated. Thanks!
Old 06-28-2022, 10:07 AM   #7
alphasaur
friendly
Drives: 17' 86
I REALLY like my HKS Spec L
I don't think I've heard an n1 that I like
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
The Following User Says Thank You to alphasaur For This Useful Post:
spcmafia (06-28-2022)
Old 06-28-2022, 10:10 AM   #8
MichaelHu
Yeah I get you lol, I'm getting really sick of the drones and the sound too, I liked it at first because it was one of the deepest sounds but I don't like it anymore
The Following User Says Thank You to MichaelHu For This Useful Post:
Old 06-28-2022, 10:27 AM   #9
MichaelHu
Thanks for the suggestions, the Borla exhausts seems like they have no mufflers? I don't think I will go with that one. I am liking the looks of the GReddy RS-Race and MPX comp RS and they both seem like relatively affordable options.
Would you suggest either one of those options? Also, would you know which one would have the least drone?
Old 06-28-2022, 11:18 AM   #10
spcmafia
spcmafia's Avatar
Out of those two, Greddy RS and MXP, the Greddy would be less aggressive with a better note, probably pricier. The HKS Spec-L has a deeper note, sounds like a growl more than anything.
Something with a muffler would drone less, the quietest one out there that I know of is the Invidia Q300, but the packing wears out overtime. After those, would be the TRD/STi, Fujitsubo, Perrin.
Sound is also very relative. Best thing would be to find people with the same header as yours, and listen to their exhausts, Youtube is good but the dBs appreciation is not great.
One of the biggest components that will determine how loud your catback is your F.P, after your headers of course. Being cat-less on headers leaves everything to the F.P, so having a single, double resonator, would do wonders without affecting performance. Not that it really matters on NA applications.
You could switch back to OEM F.P and keep the N1 and see how you like it. Or get a single/double resonated F.P, or switch your catback. Cheapest option is to go back to stock on your F.P. If it still drones, improve your hangers to either JDM or ones like Perrin.
The Following User Says Thank You to spcmafia For This Useful Post:
Old 06-28-2022, 11:39 AM   #11
brandonblt2
The Stig's African Cousin
brandonblt2's Avatar
Drives: 2014 wrb brz
Hi everyone,
Thanks in advance.
Do you have a tune for your headers and the exhaust? If not I would get that first. A tune can change the way your car sounds especially if you're now catless.
Instagram: brandonblt2
Build Thread: http://www.ft86club.com/forums/showt...86#post2219386
Flickr: brandonblt567
brandonblt2 is offline   Reply With Quote
Old 06-28-2022, 11:44 AM   #12
MichaelHu
Yes I do have OFT tune for the catless headers, got it tuned right after I put on the headers. I didn't mention it earlier because I didn't know it would affect it much haha.
Old 06-28-2022, 11:49 AM   #13
EvilPenguin04
Drives: 2015 BRZ 2004 SVT Cobra
Went with Borla on ours, it had a N1 knock off on it when we bought it highly recommend if you want quieter exhaust.
EvilPenguin04 is offline   Reply With Quote
Old 06-28-2022, 11:56 AM   #14
spcmafia
spcmafia's Avatar
Tune does not affect sound very much if not at all, it does help with flow, hence it could feel like more pressure goes thru, but hardware components play the bigger part at the end of the day. The only sound it could change is the startup one from cold starts (slightly quieter). Or from having an obnoxious popz n bangz. Other than that, the tune helps the vehicle to make make the most power out of headers and not throw a CEL.
exhaust, front pipe, overpipe, trumpet
Sound Clip of Catted UEL Header with Catless Front Pipe lc300 Engine, Exhaust, Transmission 1 03-21-2019 05:24 AM
Catted Front Pipe w/ Catless Header sound difference? HeresMyMind Engine, Exhaust, Transmission 6 09-19-2018 09:05 PM
Sound Clip Request: Catless UEL + Catted Front Pipe + Invidia N1 FR-S Matt Engine, Exhaust, Transmission 35 11-16-2015 05:27 AM
Any NY'ers install catless front pipe? ShoNUFF NY / NJ / CT / PA 19 01-04-2015 08:30 PM
Catless front pipe install? bdanisi Southern California 7 08-22-2013 08:26 PM
