Old 06-22-2022, 07:50 PM   #1
haders
Drives: 2013 Subaru BRZ
Question 2013 Subaru BRZ Airbag/control module/crash sensor help :)
Hi all!
So I have a 2013 Subaru BRZ limited that I bought from auction. The steering wheel airbag was deployed and the front seat belts were locked up. I’m trying to repair the car and just trying to find out what parts I need to replace vs what can be reused.
Do I need to buy new crash sensors because of the airbag deployment? If so, do I need to replace both front crash sensors? The damage looks like it should have only impacted the front driver side crash sensors but when I look online it seems as though the front sensors are somehow interconnected.
I bought new seat belts for the car but they didn’t come with buckles. Do the old buckles need to be replaced as well since the seat belts were locked?
I had the airbag control module reset, where is a good option to get the system married back together?
Also when I drive to get the airbag system married together, is it an issue to drive without the airbag control module in the car?
Thanks in advance for the insight guys
Sort of a car newbie here but I’m super excited to drive my BRZ.
haders is offline   Reply With Quote
Old 06-30-2022, 09:27 AM   #2
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
I'm not much help but google can be. Just add "site:ft86club.com" to the end of your search for great help.
EG: front crash sensors site:ft86club.com yielded
https://www.ft86club.com/forums/showthread.php?t=124469
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
Old 07-20-2022, 06:49 AM   #3
Stephen02
Stephen02's Avatar
Drives: 2013 Manual Trans FR-S
How’s your project going?
Once you have the airbag module reset it should be plug and play, no need to marry it to the car.
I didn’t have any issue driving my FR-S without the airbag module.
The airbag sensors should be fine as long as they didn’t sustain any damage in the crash, at least I didn’t need to replace them on my car.
I’m not positive but I think you’ll be fine reusing the female end of the seat belt as in the part with the red button that says “PUSH” on it.
You probably already know this but MAKE SURE to disconnect the negative battery terminal and wait 20 minutes for any capacitors to drain before tackling anything SRS related.
Stephen02 is offline   Reply With Quote
Old 07-20-2022, 08:28 PM   #4
haders
Hi!
Thanks for your reply, this is good info.
My project is going well, just waiting on my clock spring to come in so I can put everything together. I bought new buckles but I’m going to try and reuse the old ones thanks to your advice!
I’m excited to register and be driving my car very soon
Did you work through similar issues with your FRS?
Old 07-21-2022, 01:20 AM   #5
Stephen02
Stephen02's Avatar
Yes, I bought mine from an auction as well. I bought it thinking that there was no blown airbag as the damage was pretty light but when I got it I realized that someone had cut the driver's side curtain airbag and tucked it under the headliner!
airbag, control module, crash sensor, reset
Subaru BRZ AIRBAG module 18mateusz93 Want-To-Buy Requests 1 10-22-2018 03:15 AM
WTB airbag control module AdamAnt Want-To-Buy Requests 1 04-24-2017 11:19 AM
WTB: 2014 or 2015 BRZ Airbag Control Module austinbrz Want-To-Buy Requests 0 04-07-2016 04:15 PM
WTB: FRS oem driver airbag, clock spring, both front seat belts, airbag module 14_GT86 Want-To-Buy Requests 3 04-01-2015 12:26 AM
