Old 06-22-2022, 02:01 PM   #1
Nintain
Drives: 2015 Scion FR-S A/T
Valve replacement
So I've been trying to rebuild my engine after a roller rocker slipped out and I've been going with subaru parts for the most part. Apparently exhaust valves are on back order all the way til August so I was wondering if anyone knows of some good aftermarket valves to get instead of having to wait over a month.
Nintain is offline   Reply With Quote
Old 06-22-2022, 07:40 PM   #2
clio
Drives: 2013 Subaru BRZ
The same thing happened to my car a couple of months ago. To my surprise Subaru covered the whole rebuild despite it being a 2013 build and with a patchy service history. Mileage was relatively low at 40K though. Anyhow it was good service.
You're probably across this however coupled with this work I believe there are shims of varying thicknesses that increment by 0.02mm. There are many(!) thicknesses each with their own part number to tailor fit each valve.
clio is offline   Reply With Quote
Old 06-24-2022, 02:31 AM   #3
humfrz
I suggest you google "scion frs exhaust valves for sale".
aftermarket, engine, valves
PCV Valve Replacement with STI Valve apelpapa Forced Induction 30 06-03-2022 08:23 PM
Valve cover gasket replacement knucklehead Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 05-06-2021 06:38 PM
Private Mechanic doing Valve Spring replacement TommyW Issues | Warranty | Recalls / TSB 41 01-14-2020 02:17 PM
Has anyone considered doing the J02 valve spring replacement themselves? gutbuster DIY (Do-It-Yourself) Guides 15 11-04-2019 09:37 AM
Heart valve replacement surgery mike the snake Off-Topic Lounge [WARNING: NO POLITICS] 94 09-17-2014 01:45 PM
